Results 1 to 5 of 5
Thread: Moving toilet - need someone to double check my idea...
    DIY Junior Member charlieaf92's Avatar
    Feb 2013
    cincinnati
    Default Moving toilet - need someone to double check my idea...
    Hello
    I'm new to the forum and at the beginning stages of doing a complete bathroom remodel. Part of the remodel involves moving the vanity and the toilet + upgrading to a double vanity.
    I've done quite a bit of research about building code and the proper way to do this and I think this layout is going to fulfill all of the requirements. But, before I actually cut and start putting it together I thought I would ask some people more knowledgable than myself.
    So - I've taken some pictures of the current layout and marked them up. You will see the piping that I have test fitted and how it would run. Because there is space between the joists and the ceiling below, I will have much more than the 1/4" per foot slope requirement. The toilet will be within about 5' of the drain pipe / stack. I will be connecting into that main 3" drain using the Y fitting that is laying next to it in the pictures.
    My two biggest concerns/questions are
    - Will this provide adequate venting
    - Are the bends that I have going to pose any problems
    Anther angle
    I marked a spot called 2" sink drain possibly. This is where I am considering running 2" drain coming from the double vanity. Each of the sinks would be vented separately - so I guess this 2" drain would also act as a vent for the toilet?
    Thank you so much for your time - I really appreciate the help. Eventually I will post a start to finish thread (I'm taking pictures the whole way).
    Charlie
    We would have little interest in a "start to finish" thread, because by that time it would be too late to make any necessary corrections.
    Jan 2008
    I don't see anything technically wrong with what you have shown, but you have not shown anything in regards to how the connections will be made.
    Feb 2013
    cincinnati
    Thanks for the replies and sorry for not being more specific. The connection will be made as shown - by cutting the 3" horizontal drain pipe in two places and inserting the Y piece laying next to it.
    Jan 2008
    If you are going to cut in a sink drain as indicated, it will become a wet vent for the water closet. You will need to ensure that the wet vent is 2", not longer than 6', and that the slope is maintained at not more than 1/4" per foot.
  1. Swing Check vs. dual check vs. double check valve
    By colbymom in forum Plumbing Forum Discussion & Blog
    Last Post: 05-10-2011, 01:19 PM
  2. Double check my plan
    By pghsebring in forum Plumbing Forum Discussion & Blog
    Last Post: 03-31-2010, 10:43 AM
  3. Will this idea work for double vanity drain?
    By cable_w in forum Shower & bathtub Forum & Blog
    Last Post: 08-13-2008, 12:36 PM
  4. Basement: 4" Double WYE a bad idea?
    By Tim429 in forum Remodel Forum & Blog
    Last Post: 04-14-2008, 07:02 PM
  5. Double Check Valves .............. Again!
    By tvl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-11-2006, 08:29 AM
