Results 1 to 9 of 9
Thread: Shower-pipe to Shower-head adapter?
Hybrid View
    DIY Junior Member leomd's Avatar
    Feb 2013
    Florida
    Default Shower-pipe to Shower-head adapter?
    I am trying to find a replacement for this shower head adapter that has cracked and is leaking but am having no luck finding the piece. This adapter/reducer is from my 7/8's shower pipe 55/64's female to a 1/2" male NPT shower head thread. I imagine I will have better luck finding this piece if I know what the proper name is or if anyone knows where I can find this piece I would be very thankful. Thanks in advance.
Size:  54.3 KBName:  pic2.jpg
Size:  57.4 KBName:  pic3.jpg
    Sep 2009
    Seattle. WA
    You might find something usable in the faucet adapter/aerator section of your favorite plumbing supply joint. That's not a standard
    setup, so it doesn't have a standard name, except "adapter". When you find one, leave off the thread tape, because that's probably
    why it split. That connection almost certainly was meant to be sealed with a rubber washer or o-ring, requiring only to be made a bit
    more than finger-tight.
    It is possible that an aerator adapter, or maybe a couple of stacked ones, would do the job. Something like that can be proprietary and ONLY available from the original manufacturer, assuming they are still in business and make that item.
    Feb 2013
    Florida
    Ugh...I was afraid of that. There is no brand on the shower valve/pipe as well as everything else in the bathroom. I think when the previous owner redid the bathroom they used cheaper fixtures that were probably sourced from South America or China -you see lots of that down here in Miami. I looked at some faucet adapters but I mostly found 55/64 female to male. I really only need a solution to last a year or so until I tear this bathroom apart - looks like I might have to go the rubber pipe and pipe clamp route :-)
    Thanks again...
    Feb 2013
    Florida
    Will something like this kohler adapter work? Seems a bit steep in price...
    http://www.us.kohler.com/us/SHOWERHE...estid=1088676#
    Perhaps I need to look for a showerarm to shower head adpater
    Jan 2008
    I think most us would just unscrew the entire assembly from the wall and toss it. The shower appears to be plumbed to take any common shower arm.
  1. 3/4 to 1/2 valve/pipe for shower head
    By tomdiy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-27-2012, 06:16 PM
  2. Shower Pipe/Head question
    By mcasemo in forum Shower & bathtub Forum & Blog
    Last Post: 04-16-2007, 08:58 PM
  3. pipe adapter for shower drain?
    By dharsent in forum Shower & bathtub Forum & Blog
    Last Post: 01-22-2007, 11:54 PM
  4. Shower head pipe too close to ceiling
    By rzellmer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-26-2006, 03:58 PM
  5. Shower Head and Pipe replacement.
    By ROBSGUY in forum Shower & bathtub Forum & Blog
    Last Post: 03-27-2006, 04:53 AM
