Results 1 to 3 of 3
Thread: Recommended brands of gas water heaters
    DIY Junior Member mkulter's Avatar
    Feb 2013
    Texas
    Default Recommended brands of gas water heaters
    We're having to replace our gas water heater after 14 years.....it's leaking. I'm trying to find out what brands are recommended. I googled reviews and found that Whirlpool and GE have a lot of negative reviews.
    What brands do you recommend and does the number of years on the warranty mean it's a better water heater?
    Any help would be appreciated!
    Whirlpool is made by a consortium which puts the client's name on them...must be 4-5 major brands all made in that same factory.
    GE is made by Rheem, and generally is a decent product. If you get a GE at HD and call the 800 number, they answer Rheem. Not a bad choice either rebranded GE or a Rheem itself.
    Bradford White makes a nice product, but generally, it is only sold to plumbers, it may be hard to find if you want to buy one directly.
    In most cases, on the same heater, you can pay extra and get an extended warranty. Generally, it is not a different heater...you're buying an insurance policy. Sometimes, they'll replace the plastic drain valve with a brass one, but you can do that yourself and probably come out many dollars ahead. A longer warranty tank might have a second or larger anode, but again, those are easy to check and replace at far less than the cost of 'upgrading'; and, many of them are exactly the same with no 'upgrades' to the hardware, only a different label and piece of warranty paper.
    Feb 2013
    Texas
    Thank you for the info
  1. PRV and expansion tank recommended brands
    By Steve_P in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-24-2012, 06:53 AM
  2. Recommended best settings for 6700xtr 48,000 grain water softener
    By Lost Texan in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-05-2011, 08:30 PM
  3. What is Recommended Water Pressure??
    By wraujr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2010, 06:07 PM
  4. American Standard Brands rebadging same toilet under different brands...
    By MFfan310 in forum Toilet Forum discussions
    Last Post: 05-06-2010, 12:59 AM
  5. hot water heater brands
    By chaoster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-29-2006, 04:43 PM
