Results 1 to 4 of 4
Thread: Wet tile grout on floor
    DIY Junior Member h2oski60's Avatar
    Feb 2013
    Arroyo Grande, WA
    Default Wet tile grout on floor
    Hello, we have had long lasting problem with wet tile grout on floor adjacent to toilet and nearby shower dam. Not sure if water is coming from toilet seal or shower pan failure, or possibly both. The house is 14 years old, on concrete slab, and the shower has deteriorated to point that we are in the process off hiring a contractor to replace. He suggested simply replacing the toilet seal now, just in case. Any other suggestions appreciated - thank you very much.
    It takes very little time to replace a toilet seal.
    I would check that too.
    If the water is UNDER the tile, you may be facing a complete tear-out of the floor. That water under there will cause odor problems.
    Tile on slab...once you stop the source of the water penetration, it should be fine once it dries out...tile on subfloor, totally different thing...the wood could be all rotten. All of the nasty stuff requires a frequent source of water to continue to grow and produce the nasties...dry it up, and keep it that way, should be okay.
  1. Grout or Caulk at Tile corners?
    By scottl44 in forum Shower & bathtub Forum & Blog
    Last Post: 09-02-2012, 06:22 PM
  2. Moisture coming up through tile grout.
    By masmia in forum Plumbing Forum Discussion & Blog
    Last Post: 12-16-2008, 08:24 PM
  3. Exterior tile and grout failing.
    By midge in forum Remodel Forum & Blog
    Last Post: 08-06-2008, 06:50 AM
  4. Sealing Tile Grout
    By Schook in forum Remodel Forum & Blog
    Last Post: 04-30-2007, 09:46 AM
  5. Removing old grout tile surface
    By Mike50 in forum Remodel Forum & Blog
    Last Post: 03-19-2006, 07:12 AM
