Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Toto Fill Valve Problem
  1. #16
    Apr 2012
    New York, NY
    Quote Originally Posted by MattH View Post
    THANK YOU! Seal was totally indented - re-freeing check valve and replacing the top piece solved both problems -- THANK YOU!
    The pleasure is all ours! Glad to have a successful outcome!!
  2. #17
    DIY Senior Member Kiko's Avatar
    Jul 2009
    Royal Oak, Michigan
    I finally got around to installing this Korky fill-valve.
    I was unable to install the locking clip without removing the whole fill valve and reinstalling it.
    Is there any danger of the height adjuster turning on it's own and raising up to flood my bathroom?
  3. #18
    Apr 2012
    New York, NY
    Quote Originally Posted by Kiko View Post
    The valve is designed so that when there is water pressure (i.e. water supply valve open at wall), there is an upward push against the head of the unit. The locking mechanism is designed to move down slightly when unlocking and up slightly when locking into position. Thus when you turn the water on with the valve locked into the height you want, the water pressure will tend to make it difficult to unlock the valve even if you wanted to. Do make sure you've got it locked in place before turning on the water, and you should be fine.
    I base this opinion also on the fact that Korky now advises in its instructions that the locking clip is to be used by plumbers and multiunit managers only. In other words, folks who want the user not to mess with the thing. Toto may talk about using that clip, but only because they want the valve to be set exactly as per their instructions and not changed, i.e. so it is functioning just like the one they set and installed in the factory.
    I have seven Korky 528s of different flavors (528, 528T, 528MP) installed in our family home and I have not put the clip on a single one, with no problems.
  4. #19
    I normally install the clip after I'm done adjusting the height. It just slips up in there.
  5. #20
    Jul 2009
    Royal Oak, Michigan
    I found that it wasn't easy to clip, even before it was installed. It took a bit of effort.
    Once installed, though, I could not squeeze my hand between the fill valve and the inner wall of the tank to clip it on.
    I'll go along with WJ and not worry about it though.
  1. Eco Soiree fill valve problem
    By geoffinCT in forum Toilet Forum discussions
    Last Post: 08-02-2012, 09:24 PM
  2. Toto replacement fill valve
    By floraclo in forum Toilet Forum discussions
    Last Post: 07-19-2011, 05:21 PM
  3. Toto Fill Valve Problem Continues G-Max valve with adjusting screw
    By levitonski in forum Toilet Forum discussions
    Last Post: 12-02-2008, 12:40 PM
  4. Fill Valve Problem on Cadet 3
    By birdmom in forum Toilet Forum discussions
    Last Post: 05-13-2008, 11:07 AM
  5. Fill valve height problem
    By sergioq in forum Toilet Forum discussions
    Last Post: 02-19-2008, 04:08 PM
