Results 1 to 8 of 8
Thread: sink tailpiece with bung for RO filter brine water. Quiet.
    DIY Senior Member lifespeed's Avatar
    Apr 2007
    California
    Default sink tailpiece with bung for RO filter brine water. Quiet.
    Posted this in plumbing, but realized it might be more appropriate here:
    Is there any such thing? I am tired of the racket my undersink RO filter makes dribbling the wastewater through a saddle drilled into the top of the garbage disposal lateral pipe. No leaks, but noisy as hell.
    Surely some enterprising young man has addressed this market with a sink tailpiece that quietly trickles the water down the side of the drainpipe into the p-trap through an angled inlet? It needs to mate up to 1/4 polyethylene tubing.
    Or would moving the saddle to the sink downpipe instead of the disposer lateral be enough to quiet it? It is a permeate-pumped 45 gallon per day RO and seems to put out a decent wastewater stream, at least for an RO filter.
    Lifespeed
    Jan 2012
    California
    www.airgap.com
    It is 3/8" since that is the correct size for an air-gap faucet. Hope this helps!
    Nov 2005
    Central Florida
    Actually, they say "Inlet port directly accepts 3/8" and 1/2" O.D. poly tubing." And... there's always duct tape. To narrow down their zillion AirGap products, start at http://www.airgap.com/drainFitting.htm.
    Feb 2011
    NW Ontario, Canada
    It's still a crap shoot whether or not it will be much quieter.
    I installed my RO under the floor rather than under the counter and I ran the drain line over to my sump pit rather than to my septic tank. My softener and iron filter also discharge into my sump pit as do the humidifier, furnace, A/C, and HRV condensate lines.
    Apr 2007
    California
    Thanks, that looks promising.
    Lifespeed
    Apr 2007
    California
    That thought has occurred to me, but I'm sure it will improve on my current maximum-noise drain line connection point. It only became extra annoying after the permeate pump upgrade (which I do like) increased the flow rate.
    Here in California we don't have basements, and I don't have a sump pit. Perhaps I should water some plants with this "waste" water. Oh, but it is salt-softened, so no.
    Lifespeed
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    This is what I use. Work quite well.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by mialynette2003 View Post
    Ja, I could see how that would tend to run the water down the side without splashing.
  1. sink tailpiece with bung for RO filter brine water. Quiet.
    By lifespeed in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-31-2013, 09:05 PM
  2. Installing a sink tailpiece
    By bp77 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-07-2010, 05:11 PM
  3. I want to install an under-the-sink water filter --- in my basement
    By Pickngrin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-07-2008, 04:15 PM
  4. One faucet sink water filter
    By 51f1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-02-2008, 06:49 AM
  5. double sink problem tailpiece drain
    By missing in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-08-2005, 03:47 PM
