Results 1 to 5 of 5
Thread: chrome nipples leaking
    DIY Junior Member Taft's Avatar
    Jan 2013
    Illinois
    Default chrome nipples leaking
    hello everyone. i have a clawfoot tub water supply leaking.just wondering the best way to fix.the leak is between the half inch female fitting on the shut off valve and the half inch chrome nipple going into it.i used teflon tape 2 to 3 wraps and a good snug hand tight with a partial tightening with a wrench.any body got any better advice on getting this to quit leaking?
    It may still be too loose.
    Jan 2013
    Illinois
    that was one thing i was considering.while turning the shut off valve and holding the pipe nipple my fear is bending or collapsing the chrome nipple.is that possible and if so any good ideas how to put a hold on both parts and not cause that to happen?thanks for any input.
    Many of these parts sold here are made in China. The quality isn't always the greatest, torn threads from dull dies, inadequate depth, etc. Even if it is perfect, it takes a bit more than hand tight and a little more to create a good seal. The harder thing to get it tight enough is to do it without scratching the chrome off with the wrench or pliers. If there's another fitting on the other end of the nipple that has flats on it, use two wrenches, one on the valve, and a second one on the other fitting, and use that to tighten them both up nice and tight. Even if the other fitting doesn't have flats for a wrench, you might add one temporarily, and use that to tighten it up. THen, you must be careful not to loosen it when you take that fitting off. A good strap wrench might get it tight enough without scratching, and is a good tool to have around for things like showerheads, and other plumbing jobs with a nice finish you don't want to score up.
    Also, if you get it tight, then loosen it a bit, that can cause a leak with tape. You might want to switch to pipe dope. Once you get it nice and tight and leak-free, you can wipe the excess off, and not have to look at the tape, too.
    Jan 2013
    Illinois
    thanks for the advice i will have to try that in the morning.
  1. Chrome nipples to copper water feed lines???
    By Nick Gibb in forum Plumbing Forum Discussion & Blog
    Last Post: 03-27-2012, 06:19 PM
  2. Need help with leaking nipples
    By mears in forum Irrigation / Sprinkler Forum
    Last Post: 10-07-2008, 11:13 AM
  3. Nipples
    By Ian Gills in forum Plumbing Forum Discussion & Blog
    Last Post: 03-19-2008, 03:48 PM
  4. Leaking swivel joint on chrome trap
    By King3244 in forum Plumbing Forum Discussion & Blog
    Last Post: 06-22-2006, 06:02 PM
  5. where can I get 5in chrome nipples?
    By Lakee911 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-13-2005, 11:49 AM
