Results 1 to 11 of 11
Thread: Need Help with Toilet Flange--Moss Bay Flange
    DIY Junior Member Matt613's Avatar
    Jan 2013
    Default Need Help with Toilet Flange--Moss Bay Flange
    The flange was rusted on my closet flange so I completely removed it leaving only the PVC pipe. The PVC pipe is a 4" x 3". I read online I could use a moss bay repair flange to fix it. However when I put it around the PVC pipe it is too big. I then tried "the clam" and it is also too big. What am I doing wrong? Any suggestions? Thank you in advance!
    The repair ring is designed to notch into the slot of the old flange after carefully splitting the old metal part off...with the old flange gone, you need an entire new flange to be installed. If I'm misunderstanding you, a picture might help us understand what you have now.
    Jan 2013
    Thanks Jim. My PVC does not seem to have a slot for the flange to fit into. Here are 2 pictures: 1 with the moss bay flange and 1 with the clam.Name:  photo2.jpg
Size:  66.4 KBName:  photo.jpg
    DIY Junior Member Bluegrass Picker's Avatar
    Jan 2013
    Washington State
    I have an idea.
    Check Charlotte's catalog on page 60:
    http://www.google.com/url?sa=t&rct=j...Zru_DbSE-DXA1w
    It looks like they have a 6 3/4" flange part 1811 and 1812 which is smaller than the normal 7" flange.
    I'm not a plumber and other more knowledgeable persons here would certainly know more that I do, but it might be a possibility...
    Bluegrass Picker
    Jan 2013
    Thanks Bluegrass Picker. However, it looks like this flange would require me to remove the existing PVC pipe and replace it with this one. I was hoping to just install a new ring and not have to mess with the PVC pipe.
    Jan 2013
    Maybe another thought if I have to replace the PVC pipe...the current PVC flange fits into a 90 degree elbow. Do you think I would have any success in cutting the PVC flange off flush with the 90 degree elbow and then removing the piece of PVC from the elbow? If I could do that, I could just install a whole new closet flange into that elbow. By the way, I don't want to remove that elbow unless I have to as it goes under the subfloor, under a wall and would be a pain to replace.
    There are several brands, but they do make a special drill bit/reamer that will remove a pipe from a socket so you can glue in a new pipe. One of these is a RamBit. Whichever type you select, they have a guide to keep it centered, and a cutting bit that is sized to the diameter of the pipe you're removing. Some a cheaper than others. I've not looked in a rental supply store for one, but they may have one since this may be a one-time use for you. Trying to cut out a solvent welded pipe can be done, but it's easy to split the fitting or end up with chunks where the special tool does it quickly and leaves a nice clean socket to install the new or bit into.
    Jan 2013
    Thanks Jim. Do you know if this is a tool a plumber would normally carry on his/her truck? I have a plumber coming to the house next week to sweat in the cooper valves for my shower and maybe he would do it while he is there.
    A plumber would likely be able to handle this fairly quickly. Can't say for sure that he'd have one. Once you get the knack, some of them can remove a pipe from a fitting fairly quickly, and may not opt to go to the truck for the tool, if he has one. It can be risky, because the fitting can break. Those tools only work on sockets or hubs - they ream out the pipe that was inserted into it, leaving a hole you can glue a new pipe into. Sound like this is what you need, but I can't see it from here.
    Jan 2013
    Jim
    Yep, you are exactly right, the closet flange fits into a 90 degree hub. I will ask him to take a look next week. Thanks so much for your help. Have a great weekend!
    HOWTODO; great promotional posting, the problem is that he does NOT have a flange anymore. All he has is a "bastard" sized fitting that none of the standard repairs will work with. Part of the problem with using a "RamBit" is that the opening is NOT the proper size for it to slide through, and they work fastest if the pipe is cut off flush with the fitting and not have to "bore" through a length of pipe first. You said the flange fits INTO a 3" elbow which probably means it is a "spigot" flange, and if so, it is the WORST way to attach a flange to the system.
  1. Help - toilet flange not level and flange support issue
    By mrcleaner in forum Toilet Forum discussions
    Last Post: 11-02-2012, 02:53 PM
  2. Replies: 8
    Last Post: 03-31-2012, 06:28 AM
  3. Cast iron flange to J Tech flange
    By JP in VB in forum Toilet Forum discussions
    Last Post: 07-21-2010, 04:37 PM
  4. Oatey's Moss Bay Replacement Flange
    By USAFRet in forum Toilet Forum discussions
    Last Post: 06-06-2009, 10:57 AM
  5. Cast iron flange or flange extension (?) below tile floor
    By gardengirl in forum Toilet Forum discussions
    Last Post: 12-31-2004, 09:54 AM
