Results 1 to 5 of 5
Thread: Does this shower rough in look ok?
    DIY Junior Member Jo Deloco's Avatar
    Jan 2013
    Texas
    Default Does this shower rough in look ok?
    This is pretty straight-forward shower rough I dry fitted pending comments. I'm not sure if the the wet vent going to the lav is acceptable under IRC (NJ) with the 60 degree fitting. I rolled the combo up slightly above the drain centerline which I hope will be inspection. Thanks for your input.
    The wet vent portion should be 2"
    It looks fine.
    According to his notations, the "wet vent" IS 2", but to use a 1/6 bend at the base, the branch should rise at a 30 degree angle which means the main line should be below the floor one half the distance of the branch line dimension to the 1/6 bend, and yours does NOT appear to be that deep, but it could be because of the way the picture was taken. If the angle is correct and not "cocked" in the fitting, then the inspector should pass it, unless he goes "by the book" and wants it at a 45 angle.
    Aug 2009
    South*East
    The vent is being washed by the lav. there is no need for it to rise at a 45.
    John
    Now that you've done all that cutting, you realize that you cannot reliably dry fit pvc piping? It is nearly impossible to bottom the pipe in a fitting unless you've added the cement (which melts the plastic and then 'welds' it together). So, unless you planned for that loss of 1/4-1/2" or so per joint, everything's going to be positioned wrong. At least the pipe is cheap...and you can reuse the fittings.
  1. Shower Rough-In
    By Jacob Robinson in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-29-2011, 07:18 AM
  2. Tub/Shower Rough In
    By x81sd in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-13-2010, 01:04 PM
  3. Rough Plumbing for Delta multiple shower heads in Tub/Shower?
    By jsarin1 in forum Shower & bathtub Forum & Blog
    Last Post: 10-15-2010, 08:22 AM
  4. new tub and shower faucet rough-in
    By ditchdoc in forum Shower & bathtub Forum & Blog
    Last Post: 11-23-2008, 02:24 PM
  5. Shower rough-in...how do I do this?.
    By drkona in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-18-2007, 05:04 PM
