Results 1 to 5 of 5
Thread: Drain Pipe Question for Oatey No-Calk Drain - Height, Stability, etc.
    DIY Junior Member TheCaptain's Avatar
    Jan 2013
    PA
    Default Drain Pipe Question for Oatey No-Calk Drain - Height, Stability, etc.
    Sorry if this has been posted before but I couldn't find my exact question after 30 minutes of searching. About me for some perspective of my questions. I do not shy away from DIY work, though plumbing is not my strong point. Just something about potential and usually immediate water damage that worries me.
    My issue is that I have an acrylic shower base in a custom tiled shower on the 2nd floor that was installed about 4-5 years ago. The other day I noticed water on the ceiling of my 1st floor just under the shower. As I inspected the drain I came across my first Oatey No-Calk drain (PVS model with stainless strainer. I really didn't know what I was looking at until I found your forums and have learned quite a bit. The compression nut was very loose and came off with my fingers. I am certain that is what was causing the leak, so on to fixing or replacing the drain.
    Given the relative "young" age of my shower I'm tempted to simply get a new gasket for the drain pipe and compress it down as instructed. However when I was about to remove the old gasket I noticed the drain pipe has what I consider a LOT of play. As in I could grab the pipe using just the pressure of my fingers on the inner walls of the pipe, it moves up and down extremely easily. We are talking easily 2" of play (1" up, 1" down). This concerned me to the point that I imagined the pipe falling into the floor if the old gasket were removed forcing me to cut into the downstairs ceiling.
    So the questions really are this:
    1- Should the drain pipe have this type of "play"? My gut tells me no but hey, I have never installed a shower before.
    2- How far above the compression fitting should the pipe sit? I don't want to stress the pipe pulling it up or leave it too low.
    3- Should I go the route of replacing the gasket only or maybe remove the entire drain in lieu of one of the wingtite units (very impressed with their product given online videos and reviews).
    Some key points I've seen asked in other posts so I'll pre-empt what I can:
    -I currently have NO access from below the shower. In order to do that I'd need to cut away drywall and I really hate installing drywall. Fun as anything to smash through and demo but I am not a spakle and tape person especially on a ceiling.
    -The shower bottom (acrylic) does not flex, least not that I can see, feel, or hear. I wasn't present for the shower install but I did the demo of the old shower/tub combo so I know what is under the shower. Our floors are standard 3/4" plywood.
    -I am recaulking around the entire shower base where it meets the ceramic tile. This is being done both as cleanup (mildew, etc) and to make sure none of those seams were the cause of the leak.
    Any help you can provide would be most appreciated. My wife loves our shower and the more days she's without it the more days I'm in the dog house.
    Thanks,
    -Kirk
    Jan 2008
    The top of the pipe should be flush with the top of the seal. Pulling it up higher only creates a place for goo to build up.
    Your description of the looseness gives me a little cause for concern. I hope the trap is cemented and not threaded.
    I would replace the gasket, tighten the compression ring down good and leak test it.
    Jan 2013
    PA
    Thanks for the feedback. I did as you said but pulled the pipe up a little above the gasket. The pipe hadn't been cut level so one side is just above the gasket (like 1/16") and the other is about 3/16" above. Once I tightned the compression ring there wasn't a visible gap that I could see as an area of potential buildup. A quick leak test showed the drain was sound and no longer leaking. The real test will come after my new caulk dries around the shower door and we can run a full shower through. I may end up doing as some on here have suggested, adding a slight amount of silicone around the drain pipe and compression gasket to help prevent water from seeping there and also to help direct it down the drain.
    To use the WingTite drain, you have to remove the old one and while it can be done through the shower drain opening, it is a time consuming, tedious job.
    Jan 2013
    PA
    Thank you and the note has been made in my brain. At this point I'm hoping my entire issue was caused by the compression joint not being properly torqued a few years ago. That or I just need to make a mental note to check it every time I'm cleaning the drain. Easy enough to see if it has started sliding.
  1. Installing LASCO shower stall with Oatey No-Calk drain
    By mudcat in forum Shower & bathtub Forum & Blog
    Last Post: 02-02-2012, 09:43 PM
  2. Oatey No-Calk Drain
    By pbradley_1 in forum Shower & bathtub Forum & Blog
    Last Post: 11-03-2010, 06:11 PM
  3. Oatey Pipe joint compound on pvc sink trap and drain?
    By audioman81 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-14-2009, 06:53 AM
  4. Oatey No-Calk fiberglass shower base drain
    By rich-pittsburgh in forum Shower & bathtub Forum & Blog
    Last Post: 04-14-2007, 05:58 PM
  5. Oatey shower drain question
    By jrseaberg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2007, 02:45 PM
