Results 1 to 3 of 3
Thread: Sizing on fleck 5600 softener
    DIY Junior Member Dwdesign's Avatar
    Jan 2013
    Hawthorne, fl
    Default Sizing on fleck 5600 softener
    I am replacing my waterboss big boss and thinking to get a fleck 5600. There are 2 people in our house and our water tests 11 hardness, iron is 1.5, ph 7 . I have 3/4 pipe going into and out of the waterboss with quick disconnect hose . I need to know sizing recommendations and where would be the best web seller to purchase from. I'm going to try to do the install myself so I will probably need support from the seller.
    Jan 2012
    California
    Sounds like you are on the right track. I would recommend regular cleaning of the resin if you are not going to remove the iron before the softener. PM sent.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    From what you posted, a 1 CF softener should take care of your needs. If you have body sprayers or several bathrooms, you may need a bigger system.
  1. New Fleck 5600 - HELP!
    By Mike Larsen in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-10-2012, 05:42 AM
  2. Fleck 5600
    By CD King in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-14-2009, 07:47 PM
  3. Fleck 5600 water softener makes noise
    By JTH in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-27-2009, 07:26 PM
  4. Fleck 5600 water softener makes noise
    By JTH in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-08-2009, 08:48 PM
  5. Fleck 5600
    By jjamison in forum Plumbing Forum Discussion & Blog
    Last Post: 11-08-2007, 04:53 PM
