Results 1 to 3 of 3
Thread: leaking tub spouts after power outage
    DIY Junior Member jpbordeaux87's Avatar
    Jan 2013
    Virginia
    Default leaking tub spouts after power outage
    After my power was out for four days (ice storms in SWVA) I discovered that both my tub spouts were leaking water dramatically while the shower head sprayed at a lower capacity. I checked my sediment filter, replaced it, and tested to make sure I had full flow. What could it be?
    If this is on an outside wall, you may have split copper piping to the tub spout due to freezing.
    Whatever it is, it should have NOTHING to do with the power outage. The spouts leaking and the poor shower flow are also probably caused by two different problems. Call a plumber to fix the valves. The pipe to the tub spout should not have had any water in it so it should not have frozen or broke.
  1. VERY odd problem... HALF a power outage??
    By TangoBravo in forum Electrical Forum discussion & Blog
    Last Post: 12-27-2012, 01:04 PM
  2. After Power outage, I have pressure, but no water
    By Smitty79 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-28-2011, 05:21 PM
  3. Power Outage Question
    By brianjcollins in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-06-2010, 08:58 AM
  4. Similar Odd Power Outage problem too....
    By rundawg325 in forum Electrical Forum discussion & Blog
    Last Post: 10-08-2008, 04:11 PM
  5. how to restart pump after power outage
    By kingston in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-02-2007, 04:46 PM
