Results 1 to 4 of 4
Thread: best pipe material for storm drain line buried near ground surface?
    DIY Junior Member mb-plumb's Avatar
    Jun 2012
    Davis, CA
    Default best pipe material for storm drain line buried near ground surface?
    I need to install a 3" storm drain line, but it will have to be near the surface because the surface slope is shallow and not very long. Soil on top of pipe will be about 4". I can use corrugated or smooth poly drain line for most of it, but there will be a 10 ft section where a 2-3 ton tractor and a pick-up will be passing over it from time to time. This section will need something stronger. I'm hoping to avoid the expense of galvanized shd 40 or shd 80 PVC pipe. Any opinion on whether ABS solid, ABS foam core, PVC shd 40 pressure or PVC DWV pipe would survive? It won't be inspected, but I'd like avoid having to replace it anytime soon.
    Thanks,
    Mike
    Plumber jimbo's Avatar
    No plastic pipe at 4" depth will survive surface vehicle traffic. Try sch. 80 galv and hope for the best!
    Jan 2008
    You can find some iron pipe or you can pour cement.
    Jun 2012
    Davis, CA
    OK. I'm convinced. Steel pipe it will be.
    Mike
  1. Best pipe material for refrigerator water line
    By lnh in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-07-2014, 04:43 PM
  2. tapping into buried 2" drain line
    By pacific480 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-11-2013, 05:09 PM
  3. Replies: 3
    Last Post: 03-14-2012, 04:43 PM
  4. What's the requirement when a buried PEX supply crosses over a buried drain line?
    By Seattle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-29-2011, 06:05 AM
  5. Material for replacement buried main water line from the curb?
    By greendog in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-18-2011, 11:41 AM
