Results 1 to 4 of 4
Thread: Heat pump service disconnect
    DIY Junior Member mrbeing123's Avatar
    Dec 2012
    Louisiana USA
    Default Heat pump service disconnect
    The package heat pump in question require two circuits. Is it usual for an electrician to run one circuit large enough to run both to a loadcenter by the package unit and then take two branch circuits off of there? And then use this load center as the equipment's service disconnect?
    If I understand this correctly(and please let me know if you think I don't)...
    Run 2-#2 75c THW and 1 - #8 bare in 2" pvc conduit from the outside loadcenter/meter base on a 100amp breaker
    to
    say an Eaton 125 Amp 4-Space/Circuit CH Type Main Lug Loadcenter
    and and from this, run a whip with the two circuits with wire sizes and MOCPs per manufacturer's specs
    Name:  Heat pump SD.jpg
    Jun 2007
    North Carolina
    #2 is good for 90 amps and the #8 can be a green insulated it does not need to be bare
    Dec 2012
    Louisiana USA
    Quote Originally Posted by jwelectric View Post
    #2 Cu is rated at 115a per table 310-16. #2 al 75c is rated for 90a. or am I missing something?
    Jun 2007
    North Carolina
    Quote Originally Posted by mrbeing123 View Post
    U R correct
  1. Building Service Disconnect question
    By gtmoy in forum Electrical Forum discussion & Blog
    Last Post: 01-21-2012, 03:08 PM
  2. Water heater service disconnect question
    By turnsouth in forum Electrical Forum discussion & Blog
    Last Post: 08-16-2010, 12:26 PM
  3. Service Disconnect Fuse Contacts
    By dave9600 in forum Electrical Forum discussion & Blog
    Last Post: 01-11-2009, 06:39 AM
  4. choosing a disconnect for heat pump...
    By Randyj in forum Electrical Forum discussion & Blog
    Last Post: 07-11-2008, 02:18 PM
  5. Heat Pump Service
    By catzilla in forum HVAC Heating & Cooling
    Last Post: 05-02-2007, 04:22 PM
