Results 1 to 8 of 8
Thread: Testing Fleck 7000 flow meter advice?
Hybrid View
    DIY Junior Member cartman13's Avatar
    Jan 2013
    los angeles
    Default Testing Fleck 7000 flow meter advice?
    Hi,
    I have a Fleck 7000 head about 1 year old. It's no longer registering flow which I gather either means it's a stuck turbine, bad cord, or bad circuit board.
    I was wondering if the gurus here might have advice on how to isolate which is causing the issue w/o disconnecting the plumbing to reveal the turbine itself?
    Any help or advice would be appreciated.
    Jan 2012
    California
    Easy to do.
    Remove the sensor from the back of the valve on the outlet (attached to the end of the meter cable) and run a small magent up and down across the sensor, if the board shows water flow, it is a turbine issue. Depending on the age, water quality, and flow rates the meter regularly sees, the turbine can become worn. You can remove the turbine from the shaft and clean it carefully. An obstruction (gravel, debris, piece of wood etc) can cause the turbine to not spin under water flow as well.
    The link in my signature shows you how to get to the meter.
    Jan 2013
    los angeles
    Thanks, I tried this with a bike spoke magnet and with a stronger rare earth magnet. None seemed to register.
    Everything else works fine. When I feel the water turning hard and I manually set it to regenerate overnight it cycles and we have soft water again in the morning.
    Question is do the sensors cables go bad?
    Or will I need to replace the circuit board? I read steady 18v pos to neg on the meter plug and 12v neg to ground and only 6v positive to ground. (Not sure if that means anything).
    Thanks again for the help.
    Easy to do.
    Jan 2012
    California
    The sensor cables can go bad. It is more likely the cable than the board, or it could also be a programming issue. Do you have the valve programmed as a metered valve?
    The cable is part # 19791-01, whoever you bought the system from should be able to get a new cable for you. I would replace that before I went to tthe control board.
    Jan 2013
    los angeles
    Really appreciate the help. Too bad they don't have a way to check the cable with a multimeter. The program is set to t1.0 for the flow meter. Oddly it doesn't have the t1.2 option that I see mentioned elsewhere. It's also set to use meter delayed cycle and shows the gallons left that never change like they used to. So pretty sure something pooped out either cable or board.
    Reconnect the cable to the turbine and then push/pull the wires on the plug on the other end of the cable where it attaches to the circuit board. Run softened water in a tub as you do that and watch the screen. If it doesn't count down, pull that plug off the board and plug it back in a few times and see if that gets it to cont down.
  1. New fleck 7000 sxt questions
    By Steve424 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-04-2012, 01:31 PM
  2. Programming Fleck 7000 SXT
    By WolfB in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-23-2011, 04:53 AM
  3. Fleck 7000 Problem
    By ArayT in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-03-2011, 11:04 PM
  4. Help Programming a Fleck 7000 SXT
    By batboy in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-03-2010, 06:43 PM
  5. fleck 7000 or clack ?? help
    By gerrythegreat in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-24-2006, 08:30 PM
