Thread: drain/waste vent question
    DIY Junior Member tlt3900's Avatar
    Apr 2012
    Cypress Texas
    Default drain/waste vent question
    Hi,
    Thanks in advance for the help. I'm wanting to add a new lavatory to my bathroom upstairs. I hope i can explain my situation well enough in words.
    The existing toilet drain is about 4 feet from it's 3 inch waste vent. The new lavatory I want to add is about 6-8 inches away from the vertical section of the 3 inch waste vent for the toilet. Is it okay just to add a sanitary Tee into the waste vent and add my new lavatory drain there? Will creating this wet vent be an issue?
    Or, is it a better idea to run a separate vent line off of the new lavatory and then tie into the waste vent higher and run a separate drain for the lavatory and tie in with a Wye connector near the toilet drain.
    DIY Junior Member patma's Avatar
    Jan 2013
    Kentucky
    I just spent a ton of time researching toilet venting. Seems there is just as much support for a vent as there is for no vent. (A real hotly debated issue) I elected to wet vent the drain via a lav wye 7 feet from the flange. The toilet plumbing I removed for this remodel had no vent at all and the 3" drain line ran 11 feet. I worked fine for many years. I did not know it but toilets are considered self venting but codes require them on systems to protect other trap seals. (I'm an a DIY'er so take my comments w/ caution.. Good luck. Great site here for info...
    Jan 2008
    There is no issue with your lav drain being connected. The lav will still need it's own vent.
  1. Testing Drain Waste Vent
    By techinstructor in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2010, 12:08 PM
  2. vent/waste line for moving toilet question
    By mousejockey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-26-2009, 08:54 PM
  3. combination waste and vent question
    By perrycat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-01-2007, 07:34 AM
  4. Loop vent question: waste connection
    By Riosman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-30-2006, 01:28 PM
  5. Kitchen Sink waste and vent question
    By trinculo54 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-11-2005, 04:19 PM
