Results 1 to 7 of 7
Thread: Toilet "sucking" water from tub trap?
    DIY Junior Member Houseman's Avatar
    Jan 2013
    New Brunswick
    Default Toilet "sucking" water from tub trap?
    I have what I think is a weird problem. When I flush my toilet, there is a gurgling sound in my bath tub. When I run some water in the tub,and then flush, the noise stops, for a bit, (3/4 flushes) and starts again. Even more weird. this only happens on an intermittent basis. Sometimes it will go weeks without happening, then do it for a week. It seems that for some reason the toilet is sucking the water from the trap for the bath. I thought it might have something to do with the snow on the roof covering the vent stack but I just checked it from the ground) and it is open. Could there be a plug of snow inside the stack pipe that I can't see from the ground? (stack should be warm enough to prevent that?)
    Any thoughts/ideas would be most welcome. This is very annoying!
    Trev
    That is normally because the tub is not vented, and the toilet siphons the p-trap.
    Jan 2013
    New Brunswick
    Would that cause an intermittent problem Terry? I have been reading here for an hour and came across threads that talk about dry traps(this one is used daily). I am kind of concerned now because I also read about "partial" clogging of the lines.
    If it is siphoning, it is because the toilet is flushing "good", so it would not be a stoppage problem. But, it could also be caused by air being forced out of the tub drain because of a stoppage. Your problem could be caused by NO vent, an IMPROPER vent, or a PLUGGED vent. The vent COULD be plugged with frost and you would not be able to see it without looking INTO it.
    Jan 2013
    New Brunswick
    Thanks guys. I would tend to think that it is flushing "good". Nothing has changed in years so its not "no"vent or "improper" vent. Perhaps frost plug. I guess as long as it flushes well all is good.
    Thanks for your time both of you. I do appreciate it!
    FWIW, a toilet will often flush well without any vent...it's just the other things on the line that may have problems.
    quote; a toilet will often flush well without any vent
    FWIW, almost EVERYTHING will drain better without a vent. The vent is to keep it from draining so good that it siphons the water out of the trap. I once had a customer who wanted me to connect his tub drain to the stack. He had a 10' pipe dropping out of the tub all the way to the basement where he wanted me to make the connection. I told him that if I made that connection, the tub would drain so "good" that it would suck everything in the room, including the baby, down the drain when he pulled the plug. A bit of hyperbole, but he got the message.
  1. Installing a "bottle trap" drain in an older house
    By boy412 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-30-2012, 01:51 PM
  2. Is this a "P" or "S" Trap or which is the better alternative?
    By dw85745 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-30-2012, 07:28 AM
  3. "Machine Gun" or "Thud" and a Weeping Toilet...oh my!
    By maxxis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-22-2009, 07:38 PM
  4. "Trap" water
    By SteveW in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-04-2007, 06:50 AM
  5. Say "no" to the AS Champion toilet & "yes" to Toto
    By badeb in forum Toilet Forum discussions
    Last Post: 04-18-2006, 09:32 AM
