Results 1 to 9 of 9
Thread: old faucet handles
    DIY Junior Member reyn's Avatar
    Feb 2012
    nj
    Default old faucet handles
    Hi.
    I'm confused on how to remove these handles. I would like to replace them if I can.
    Any help is appreciated. Thanks.Name:  old faucet handles.jpg
    Plumber jimbo's Avatar
    The index buttons..."h", "c", etc remove and there is a handle screw. THe buttons probably pry off with a butter knife. If they don't pop right out, they might unscrew, but yours look like they will pop off.
    With any luck, the screw will the come out OK. You may need then a handle puller to remove the handle.
    Jan 2008
    Those handles are probably chrome plated bronze, and you will not be likely to find another handle of that quality. Polishing might be a good option.
    FWIW, there are companies that will clean and replate those to better than new condition, but, I'd seriously consider replacing with a modern valve. Depending on their workload, it may only take a few days. I think the money would be better spent elsewhere, but it's your house.
    DIY Junior Member bcarlson78248's Avatar
    Feb 2013
    Alexandria, VA
    I have what appear to be the same faucets, and the center button (H and C) unscrew. There is a phillips head set screw behind the button. I was able to remove the screw and work the handles off the splined shaft. After removing the screw I was trying to work the handle off the shaft and thought they would never come off, and then the handle suddenly broke loose.
    Bruce
    judyfholmes
    Guest
    Handle suddenly broke? Now will you be able to fix another handle over there? A plumber might do the job well here but since you tried, may be it didn't turned out quiet well. Or did it?
    Normally, the handle would "not suddenly break", but the stem's end WOULD snap off if you were trying to remove the handle incorrectly. Those appear to be American Standard handles and if so, the screw "caps" unscrew to give access to the handle screws underneath them.
    Feb 2013
    Alexandria, VA
    I have to be more careful about my wording. When the handle "broke loose" it slipped off the splines, which is exactly what I wanted it to do. Nothing broke on the fixture.
    My point was that the handle is a friction fit on the splines and it may not come off easily even after you remove the set screw.
    Bruce
    DIY Junior Member shrews1's Avatar
    Aug 2013
    Iowa
    i have got the same set except not the middle one- the hot side has a leak- rather a "run" a very fast leak! I think all i need is a new seat or something but once i get handle off- how do i get wall plate off ? any help would be appreciated! thanks!
  1. Leaking faucet handles
    By tostaky in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-29-2012, 04:51 PM
  2. Help! how to take off old Gopher tub Faucet handles
    By dy in forum Shower & bathtub Forum & Blog
    Last Post: 05-03-2010, 12:07 PM
  3. Leaky faucet; handles won't come off
    By casualfc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-03-2006, 05:30 AM
  4. Faucet Handles will not come off
    By tjones in forum Shower & bathtub Forum & Blog
    Last Post: 08-14-2005, 09:00 AM
  5. Set screws in faucet handles
    By merilyn in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-09-2005, 06:26 PM
