Thread: Boiler Front Gasket Leak
    DIY Junior Member jmacl's Avatar
    Jan 2013
    RI
    Default Boiler Front Gasket Leak
    Hi All,
    I just had a quick question about the size of the job to replace the front gasket on my boiler.
    The sweating shouldn't be an issue for me, but I am a little worried about draining the boiler.
    Also the construction of the internals after the plate is removed concerns me, I am not sure what to expect
    from the thermostat, and how the front plate will actually remove. So I was hoping that someone with
    experience could tell me whether I can DYI this, or if I should leave it for a pro.
    The boiler is a:
    Trianco Heatmaker
    Serial: 1093-1199
    Model: DBC-85
    Are there torque specs for the plate?
    Possibly the cause of the failure was over tightening?
    The gasket from the side, looks water logged:
    Front shot:
    Right side, not leaking:
    Thanks in advance!
    James
    Can't answer your question, but I had a Trianco Heatmaker (different model), and finally replaced it because it was so much of a pain to keep running. It was the Heatmaker II, with the domestic hot water built in.
    Jan 2013
    RI
    Yeah, I am getting that feeling that it might need more maintenance than it's worth. I need to finish the season out with it, and I think it will make it, but if it was a 4-6 hour job I would probably do it. Anyway, thanks for the input!
    Jan 2013
    RI
    Well it turns out it should be fine for the rest of the season. I was told to just tighten it up, and it will last, but I should have someone out to work on it once we are not longer heating.
  1. Leak from overflow gasket on tub drain
    By yaozer in forum Shower & bathtub Forum & Blog
    Last Post: 11-21-2009, 06:15 AM
  2. Leak at flush valve gasket - How to fix?
    By vivona in forum Toilet Forum discussions
    Last Post: 06-28-2006, 07:06 PM
  3. Tub Leak Overflow pipe gasket
    By joyvv in forum Shower & bathtub Forum & Blog
    Last Post: 10-23-2005, 05:42 PM
  4. Drake tank gasket can leak
    By kwarner in forum Toilet Forum discussions
    Last Post: 09-25-2005, 01:11 PM
  5. Leak from replacement drain gasket
    By Paddy Coughlin in forum Plumbing Forum Discussion & Blog
    Last Post: 12-30-2004, 07:31 PM
