Results 1 to 4 of 4
Thread: Seized gas pipe
    DIY Junior Member njbillt's Avatar
    Jan 2013
    new jersey
    Default Seized gas pipe
    Hi. I want to extend my black iron gas piping for a new water heater and gas grill. My pipe is 1-1/4 and has a plug at the end of the line that I simply cannot loosen. It's only a few years old, but the sealant the guy used is black, and has hardened. I thought the idea behind pipe sealant was it's supposed to be able to be worked with later. The stuff I'm using says it's non-hardening. Any ideas how I can get this plug out to continue my run would be appreciated.
    Bill
    Plumber jimbo's Avatar
    2... 18" wrenches
    It can take a surprising amount of torque to loosen a fitting. Make sure to help hold the fitting with another wrench while removing the plug. You might need two people and an extension to the wrench.
    Jan 2013
    new jersey
    You had that right. I slipped 3' of pipe over my wrenches and it came loose. Thanks again.
  1. Concrete Pipe 90 bend flush with basement floor. How to connect new pipe?
    By Johnbentwin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-18-2013, 04:14 PM
  2. Seized Bathtub Faucet
    By fbskiracer in forum Shower & bathtub Forum & Blog
    Last Post: 02-09-2009, 09:03 AM
  3. New Well Pump Seized already
    By SergioMastro in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-28-2008, 03:20 PM
  4. 3 year old well pump motor case corroded so badly it seized up?
    By blown in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-27-2008, 06:49 PM
  5. leaking pipe under sink, stop cock seized
    By shaktiman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-14-2005, 12:33 PM
