Results 1 to 2 of 2
Thread: How does a modulating gas burner adjust the fuel mixture?
    Retired Software Engineer gypsydoctor's Avatar
    Jan 2013
    Newton, MA
    Default How does a modulating gas burner adjust the fuel mixture?
    My new Burnham Alpine gas boiler uses a variable speed blower to modulate the flame output down to 1% increments. How does it adjust the gas flow to keep the proper fuel/air mixture at all flow rates?
    An old car does this with a carburetor. A new car has a mass air flow detector feeding a computer which meters the fuel injectors.
    Mark Dionne
    Retired software engineer
    Master Hot Water Mpls,MN BadgerBoilerMN's Avatar
    Mar 2011
    Minneapolis
    A negative pressure gas valve with a computer controlled combustion blower, just like your car with a less dense fluid.
  1. Change from fuel oil burner to propane.
    By Rughead in forum HVAC Heating & Cooling
    Last Post: 04-29-2013, 07:32 AM
  2. Is Carrier 59MN7A060 a modulating furnace?
    By CurbYourEnthusiasm in forum HVAC Heating & Cooling
    Last Post: 12-26-2012, 09:44 PM
  3. Modulating V Non and Aluminum Heatx v Cast Iron
    By srbell in forum Boiler Forum
    Last Post: 07-24-2011, 10:41 AM
  4. choosing the right size modulating furnace
    By Vixter in forum HVAC Heating & Cooling
    Last Post: 04-27-2008, 06:39 AM
  5. Hot to cold water mixture
    By Bob1000 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-08-2007, 02:21 PM
