Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Newbie here! problem getting water from my lake
  1. #16
    DIY Junior Member MUGSHOT's Avatar
    Jan 2013
    broward county florida
    Well,
    I am having difficult time trying to bleed the system. How long will it take to pick up the water from the lake, I bleed the system and what it does is bring the water that is in the inlet side all the way to lake but not beyond the check valve. So it is not picking up the lake water, this pump does not have a bleed screw on top so how long can I run the pump to allow it to bring up the lake water.
    Thank you all for all your help
  2. #17
    Moderator valveman's Avatar
    Mar 2006
    Those Gator pumps are self primers, which have a flapper check built inside. I think you will need a tee on the suction line to be able to prime the suction pipe to the lake.
  3. #18
    Jan 2013
    At last! My pumped primed and is now pumping water like a beast. Thank you all for all your help in this matter, now my grass can look green again.
  1. lake water supply setup. in Ct lake
    By tooks7 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-07-2012, 12:10 PM
  2. Strange hot water problem! Help a newbie!
    By kissiffer4 in forum Water Heater Forum, Tanks
    Last Post: 12-05-2009, 02:53 PM
  3. Newbie with a Problem
    By lucky13 in forum Shower & bathtub Forum & Blog
    Last Post: 02-20-2009, 01:33 PM
  4. water lawn from lake
    By Amopower in forum Irrigation / Sprinkler Forum
    Last Post: 03-28-2007, 07:10 PM
  5. HELP! Newbie w/sprinkler problem
    By htioki in forum Irrigation / Sprinkler Forum
    Last Post: 09-06-2006, 06:53 AM
