Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Newbie here! problem getting water from my lake
    DIY Junior Member MUGSHOT's Avatar
    Jan 2013
    broward county florida
    Default Newbie here! problem getting water from my lake
    Hi there,
    I live in south florida with a lake behind my house. I have a 2 hp goulds pump and it sits above the water line and it is mounted 100 feet from the lake. I ran 2' inch pvc to the back with a horizontal check valve at 80 feet. My strainer sits about 15 feet into the lake submerged. I can not get the water to come up, I dont know if the check valve has to be put in the end where the strainer is. I have been searching on here for my issues but havent found anything that explains my situation.
    Thanks in advance
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    You have to fill that line and the pump full of water before it will pump. If you have any high spots in the suction line it is almost impossible to get the air out. The foot valve is all you need, it is just hard to draw water from that far away.
    Jan 2013
    Thank you,
    So instead of the check valve at the end, all I need is the foot valve or both?
    Yes, I have high points all the way to the back, it is about three feet above the
    lake water.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    You only need a foot valve at the end of the suction line.
    Jan 2013
    Quote Originally Posted by craigpump View Post
    Thank you, I will get on it this weekend! now I can sleep in peace!
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by MUGSHOT View Post
    If you want restful sleep, put in a submersible. Not only will it pump more for less money but it will never need priming.
    Jan 2013
    Well,
    I bought the foot valve and installed it. I primed the pump and hit the switch, all I brought was the water left in the line from the city water. I did it a few times and nothing happened, now I am totally lost! Why is it that my 2 hp gator pump does not open the valve to let the lake water in? I am priming it on the inlet side, what else could I try before I call an expert? thank you in advance
    Apr 2012
    ct
    Are you putting the water into the top port on the pump?
    How much water are you putting into the pump?
    Are you allowing all the air to burp out before putting the plug in and turning the pump on? If there is any air in the suction line the pump will not pick up prime.
    Whenever I work on a jet pump I like to have a ball valve on the discharge side so I can bleed off the air slowly.
    Jan 2013
    Thank you craigpump,
    I have the city water hooked on the inlet end of the pump. in front of the pump threw a water hose valve. In the bottom of the front of the pump there is a plug, I do not see any other plugs anywhere to bleed the system. I never bleed the system, so how am I suppose to bleed the system to get the air out? that is what the pump sounds like it has air in it. I will take a picture of my set up in the morning....thank you
    Apr 2012
    ct
    It sounds like you are keeping the hose hooked to the pump when you start the pump. What you want to do is slowly fill the pump and suction line through the top port on your pump. Allow the air to burp out, refill the pump, burp the air, refill the pump.............When the pump and suction line are both completely full of water, disconnect the garden hose and then turn the pump on. If you don't have a valve on the discharge side of the pump, leave the plug loose so what little remaining air will bleed out.
    Welcome to the world of centrifugal/jet pumps.
    Jan 2013
    Here is my well pump, the only bleeder screw I see is that one on the bottom. If that is the bleeder screw, what do I do? remove it completely or loosen it. Again thank you for all the help
    Feb 2011
    NW Ontario, Canada
    Bleed the air out on the discharge side where the green hose connects.
    Jan 2013
    LLigetfa,
    I bleed it with the city water with the pump running or off. I`m sorry for all these questions, I just want to get it right.
    Thank you
    Feb 2011
    NW Ontario, Canada
    Both. Close off the discharge ballvalve. Pressurize the system with city water. Close off the city water. Open the bleed a small amount and turn on the pump. You want it to build pressure but at the same time bleed off the air. If you lose all the pressure, open and close the city water to get the pump wet. Lather, rinse, repeat.
    Jan 2013
    I will try this LLigetfa,
    Thank you again,
    Note: the foot valve is installed horizontal instead of vertical at the lake end. I just thought I should mention this.
  1. lake water supply setup. in Ct lake
    By tooks7 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-07-2012, 12:10 PM
  2. Strange hot water problem! Help a newbie!
    By kissiffer4 in forum Water Heater Forum, Tanks
    Last Post: 12-05-2009, 02:53 PM
  3. Newbie with a Problem
    By lucky13 in forum Shower & bathtub Forum & Blog
    Last Post: 02-20-2009, 01:33 PM
  4. water lawn from lake
    By Amopower in forum Irrigation / Sprinkler Forum
    Last Post: 03-28-2007, 07:10 PM
  5. HELP! Newbie w/sprinkler problem
    By htioki in forum Irrigation / Sprinkler Forum
    Last Post: 09-06-2006, 06:53 AM
