Results 1 to 6 of 6
Thread: Need help/ideas on how to remove a plastic pipe fitting
Hybrid View
    DIY Junior Member The Dude's Avatar
    Jan 2013
    Georgia
    Default Need help/ideas on how to remove a plastic pipe fitting
    Hello all - first time poster - I need to remove a copper pipe dropping down from a brass t-connector in a copper pipe assembly coming from a steam generator to the steam bath.
    Below picture shows the t-connector and the pipe needed to remove at the left, and at the right a close-up view of the connector I'm working with.
    It is a beige, thin plastic piece connecting the copper pipe to the brass t-connector. the pipe turns freely and moves within the t-connector, so I know its not glued in. Any ideas on how to get this plastic piece from the t-connector?
    thanks!
    Nov 2010
    Maine
    Push the plastic towards the fitting while pulling on tha pipe
    shark bite or equivalent removal tool
    gently push the pipe towards the fitting, then press the plastic piece towards the fitting, and while holding that,, pull the pipe out. 3 hand job. A horseshoe-shaped sharkbite tool makes it a one man job,
    Place a Crescent wrench over the copper tubing, then use it to push the ring inward while pulling on the copper tubing.
  1. ABS repair, remove pipe from fitting
    By big2bird in forum Plumbing Forum Discussion & Blog
    Last Post: 11-13-2012, 09:51 AM
  2. Can't remove Tub/Shower Drain piece! Tried pliers but looking for tool or ideas...
    By Dallas Stuart in forum Plumbing Forum Discussion & Blog
    Last Post: 10-01-2012, 05:50 PM
  3. how to remove plastic pipe stuck inside copper pipe
    By libinius in forum Plumbing Forum Discussion & Blog
    Last Post: 04-01-2012, 10:16 AM
  4. Remove Brass Fitting from Iron Pipe
    By tev9999 in forum Plumbing Forum Discussion & Blog
    Last Post: 02-15-2012, 05:20 AM
  5. compression fitting with plastic pipe
    By donk in forum Plumbing Forum Discussion & Blog
    Last Post: 01-20-2007, 01:46 PM
