Results 1 to 12 of 12
Thread: Fleck 7000 Installation Questions
    DIY Junior Member btables's Avatar
    Jan 2013
    Minnesota
    Default Fleck 7000 Installation Questions
    We just finished building our new house and moved in. I need to get a water softener. I'm on city water and the water quality is 17 GPG, iron is at 0.1 ppm, Calcium 210 ppm, Magnesium 210 ppm and Manganese is 0.056 ppm.
    After reading through these forums and doing some research I think I'm going to go with the Fleck 7000SXT. It's just me, my wife, and 2 kids in the house so would 48k be a good size?
    I installed a water heater at my last house with copper piping so I'm hoping I have the skills to install this myself as well. However, the new house is all PEX piping, which I've never done. I saw a section of 1" PEX that the plumbers labeled "Water Softener Rough In" so I believe I just need to cut into that, add an elbow fitting to each end, and run 1" pex from the fittings to the water softener. Does all that sound correct?
    Jan 2012
    California
    I would recommend a 2 Cu. ft. 7000SXT for maximum efficiency. It would be listed as a 64,000 grain unit, but its actual real world capacity would be closer to 48000 grains.
    4 people x 65 gallons x 18 grains x 7 days minimum between regenerations = 32,760 grains. A 2 cu. ft. unit would regenerate about every 10-12 days.
    Hope this helps!
    Jan 2013
    Minnesota
    Thanks, I appreciate that! I didn't realize the real world capacity was that much lower. I'll go with the 2 cu. ft. unit instead. I'll be connecting it into my 1" PEX line so I should choose the Noryl 1" Male NPT connection, correct?
    How does this look for options? Should I change the distributor tube to 32MM HI-FLOW Distributor?
    Insulating Jacket: None
    Brine Tank Size: 18x33 Round Brine Tank
    Res-Care Feeder: None
    Resin Media Option: Hi-Capacity Resin - 8% Crosslink
    Distributor Tube: 1.05" STD Distributor
    Turbulator Option: None (12x52 tank)
    Plumbing Connection: BYPASS, Noryl 1" Male NPT
    Jan 2012
    California
    My personal preference would be the 18x40 brine tank, I like to ignore my system for 6 months to a year before dealing with salt, but it is taller, lifting the bags that much higher may be a problem for those who have difficulty lifting 40-50 pound bags.
    Go with the 32MM, it almost guarantees a better bottom screen. The 32 MM bottom screens are only available in the highest quality version by Pentair or Clack. It also gets rid of the internal 1.05" x 32mm adapter which you saw on a very recent thread was installed improperly from the assembler.
    10% crosslink if it is available is preferred, but not critical
    no turbulator
    Plumbing connections,bypass is a must, match your existing plumbing size. Noryl threaded is correct since you have pex. See if you can get the 90 degree kit, 61601.
    DIY Member silversaver's Avatar
    Jan 2013
    Orange County, CA
    highly recommended 90 degree kit if you plan on running the pipes on wall and bring your softener closer to wall. I wish I had order the kit on my installation and now I'mm running my 7000 sideway....
    Nov 2005
    Central Florida
    Is there a similar 90 kit for older 2510 installations?
    Jan 2012
    California
    Yes, 19620-01, sorry about the bad picture. Name:  19620-01.jpg
    Nov 2005
    Central Florida
    Perfect; thanks. Is there a comprehensive catalog of Fleck parts & accessories available to cutomer types?
    Jan 2012
    California
    Not really, mainly just to dealers, not end users. Their basic catalog is over 100 pages, and this does not include complete valves, only parts and components for valves. Then there are tanks, filters, housings, pumps, etc. Pentair owns a lot!
    You can check them out at pentairaqua.com
    Jan 2013
    Minnesota
    Thanks for all the great advice. I'm going ahead and ordering what you suggested with the 90 degree connection. As far as connecting the softener to my 1" PEX line, do the SharkBite fasteners work well? I don't have PEX crimpers and such so I was wondering if those "tool-less" fasteners work well for connecting a softener or if they are more of a gimmick.
    Nov 2005
    Central Florida
    Quote Originally Posted by Mikey View Post
    I found a complete catalog online about a month ago. I don't know how current it is, and the prices are probably not accurate. It wasn't searchable, just low-res scanned images of the complete parts list, with a page-number list at the top of the table of contents -- you click on a page number and that page pops up. But it was sort-of useful. I made a better index -- you can find the page number, knowing the part number -- but now I've lost the site. Has anybody seen anything like this? I'll trade a copy of the index for the URL .
    Jan 2012
    California
    If the shark bites are done correctly, they should be trouble free for decades.
  1. New fleck 7000 sxt questions
    By Steve424 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-04-2012, 01:31 PM
  2. Fleck 7000 questions
    By cgarai in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-16-2012, 12:47 AM
  3. A couple of questions-- Fleck 7000
    By fatdaddy in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-22-2012, 09:34 AM
  4. Programming Fleck 7000 SXT
    By WolfB in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-23-2011, 04:53 AM
  5. Fleck 7000 Problem
    By ArayT in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-03-2011, 11:04 PM
