Results 1 to 6 of 6
Thread: Is 1/2 inserted into ABS fitting OK?
    DIY Junior Member Buttonsrtoys's Avatar
    Nov 2012
    Nova Scotia, Canada
    Default Is 1/2 inserted into ABS fitting OK?
    I'm just finished installing my 3" drain for a new powder room. I got the pipes inserted the full 1.5" in each fitting except one pipe that was in a really cramped spot, which I only got inserted half way (3/4") into the fittings on each end. Its supported with straps and well glued. Because it's in such a cramped spot, I'm hoping not to have to take it out. Is it OK?
    Nov 2010
    Maine
    The short answer is No. The long answer is Noooooooooooooooooooooooooooooo
    Nov 2012
    Nova Scotia, Canada
    Can you elaborate? is the concern that it will fail down the road even of it's not leaking now?
    Nov 2010
    Maine
    Read your code book.
    Nov 2012
    Nova Scotia, Canada
    I'm a home owner. I don't have a code book. Regardless, I'm just liking to know whether it will hold.
    Jan 2008
    If it's installed 50% of the way, there is a 50% chance of it failing.
    Your goal in any DIY project should be to do it at least as good as a professional tradesman would.
    Plastic fittings and cement are cheap. You should cut it out and fix it.
  1. How far down should bush be inserted into shower drain
    By Kimster in forum Plumbing Forum Discussion & Blog
    Last Post: 11-02-2011, 10:41 AM
  2. What kind of union fitting is this? Ford Fitting
    By DavidTu in forum Plumbing Forum Discussion & Blog
    Last Post: 04-21-2011, 10:25 PM
  3. will NPT fitting work with IPS fitting?
    By rick.a in forum Plumbing Forum Discussion & Blog
    Last Post: 04-14-2011, 07:58 AM
  4. How to replace a copper fitting close to another fitting
    By jfhardy in forum Plumbing Forum Discussion & Blog
    Last Post: 11-26-2008, 08:48 AM
  5. 5/8 Fitting
    By pvoight in forum Plumbing Forum Discussion & Blog
    Last Post: 07-04-2007, 06:17 AM
