Results 1 to 6 of 6
Thread: Washing machine/sink drain and vent
Hybrid View
    DIY Junior Member garrettgjp's Avatar
    Jan 2013
    Grand Forks ND
    Default Washing machine/sink drain and vent
    I am a new home owner and this will be my first ever DIY plumbing project.
    My washing machine drains into the laundry sink and I am wanting to have it drain into a seperate pipe and figure out how to vent it properly as well. I have included pictures of the current setup, any suggestions or advice would be greatly appreciated since I am not sure how to go about this correctly.
    Name:  Winter 2012 018.jpg
Size:  45.7 KBName:  Winter 2012 019.jpg
Size:  49.4 KBName:  Winter 2012 020.jpg
Size:  54.0 KBName:  Winter 2012 021.jpg
Size:  57.1 KBName:  Winter 2012 022.jpg
    Plumber jimbo's Avatar
    The photo shows an S-trap which is illegal, because it self-siphons. Also, it appears to drain into a drain stack, and therefor there is no vent.
    Jan 2008
    First you will have to cut out a section of the cast iron and install wyes for the new drains. Then you will have to run a new vent from the basement up through the roof. Unless you are well equipped and quite skilled, this will not be a very good project for you to learn about plumbing.
    Oct 2011
    Above fitting #5, there can be no other fixtures draining into that stack to have that vent setup be proper?
    Jan 2008
    Quote Originally Posted by Hammerlane View Post
    That is Correct!!
    Jan 2013
    Grand Forks ND
    Thanks, this is clearly over my head. I'll hire someone to take this on and watch and learn. Thank you again to everyone who responded!
  1. Please look at my washing machine/utility sink drain setup...need advice.
    By Dave88LX in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-15-2013, 03:36 AM
  2. Converting Washing Machine Drain to Sink Drain
    By TheJazzMan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-13-2012, 01:23 PM
  3. Drain question: new utility sink + washing machine drain
    By brownetowne in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-05-2012, 06:14 PM
  4. Help with Washing Machine trap/drain/vent
    By schomeowner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-08-2008, 09:29 PM
  5. Washing Machine Drain- vent needed?
    By jdkimes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-11-2006, 03:05 PM
