quote; I see there is a brand at Slowes that claims to work down to 0 degrees F.
Then that is what you should use.
This week I'm planning on installing a yard drain of 4" diameter, SCH 40 PVC. I want to solvent weld the joints to prevent roots from entering.
It is going to be in the 10 degree Fahrenheit range. Is there a PVC cement that can be used with GOOD results in this temp.? I see there is a brand at Slowes that claims to work down to 0 degrees F.
Thanks in Advance!
Bill
"Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
Gore Vidal.
