Results 1 to 3 of 3
Thread: Hot water dispenser help
    DIY Junior Member lati_cz's Avatar
    May 2009
    California
    Default Hot water dispenser help
    I have Insinkerator instant water dispenser, the faucet broke and new one is expensive. Friend gave my one, but it's different brand. Mine faucet has a 4 lines, his only 3. I have extra line - vent line on dispenser. What purpose has a vent line? Is there any way to install it so it works? Thank you. Michal
    It vents the steam created when the water is heated. I would not install it if it were I. The other three lines are cold water into the faucet, cold water down to the tank, and hot water out of the tank to the faucet. How old is the unit?
    May 2009
    California
    I am not sure how old is it, it came with the house. I thought it drains a steam so I dumped it directly into drain, but water runs from it. I'll check the unit, could be broken. Thank you, Michal
  1. Instant hot water dispenser
    By lilibud in forum Plumbing Forum Discussion & Blog
    Last Post: 10-10-2011, 03:04 PM
  2. Instant Hot Water Dispenser Problem
    By Kiko in forum Plumbing Forum Discussion & Blog
    Last Post: 02-08-2011, 08:17 PM
  3. Hot Water Dispenser Leaks
    By jk60 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-23-2010, 02:04 PM
  4. ISE Hot Water Dispenser Installation
    By mortimer74 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-13-2007, 05:46 PM
  5. Hot water dispenser leak
    By Joerg in forum Plumbing Forum Discussion & Blog
    Last Post: 12-03-2006, 02:14 PM
