Results 1 to 2 of 2
Thread: Cold Weather PVC Cement?
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Cold Weather PVC Cement?
    This week I'm planning on installing a yard drain of 4" diameter, SCH 40 PVC. I want to solvent weld the joints to prevent roots from entering.
    It is going to be in the 10 degree Fahrenheit range. Is there a PVC cement that can be used with GOOD results in this temp.? I see there is a brand at Slowes that claims to work down to 0 degrees F.
    Thanks in Advance!
    Bill
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    quote; I see there is a brand at Slowes that claims to work down to 0 degrees F.
    Then that is what you should use.
  1. Vent and cold weather = draft
    By yar02169 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2013, 02:57 PM
  2. Cold weather glue
    By Mudball in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-13-2009, 03:29 PM
  3. Cold weather prevention
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-01-2006, 06:25 AM
  4. Is CPVC Any Better Than Copper Or Steel In Cold Weather?
    By PM5K in forum Shower & bathtub Forum & Blog
    Last Post: 10-16-2006, 08:15 AM
  5. prevent well from freezing in cold weather
    By cidgrad98 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-11-2006, 01:35 PM
