It should go away by itself.
installed guts for toilet, hooked up water line and get rumble when turned on. air in the line but i don't know how to bleed it. thanks
Air will vent itself right away.
Sounds like a loose washer.
If still noisy check the washer in the stop if that is what you used when you put in the new parts.
