Results 1 to 4 of 4
Thread: Hardie Primer before installing Kerdi
    DIY Junior Member Lunker68's Avatar
    Jan 2013
    New Jersey
    Default Hardie Primer before installing Kerdi
    I read somewhere that spraying the hardie board with a "level-quick primer" before installing kerdi it will make things a lot easier because the hardie will then not suck the moisture out of the thin-set.... can anyone second this solution?
    DIY Member jadziedzic's Avatar
    Aug 2006
    New Hampshire
    I used Laticrete's primer on the Durock in my shower prior to installing the Kerdi; I believe I applied two coats a day apart. There were no problems with the thinset drying out too quickly, and since this was my first Kerdi project I'm sure I took a LOT longer than an experienced installer.
    Nov 2009
    VA
    I used the primer on my cement board also before the Kerdi. I did one coat. Seemed to work fine. Didn't have issues with the thinset drying out.
    Jan 2013
    New Jersey
    Thanks guys.
    I sprayed the hardie with primer,let it sit for a few hours and then installed the kerdi. I'm a first time installer, and it went smooth as silk, no drying out of the thin-set and no air bubbles. I was honestly worried about the install, but it was easy as pie.... :-)
  1. Un-stick PVC Joint that got a little primer in it? (Kerdi Drain)
    By hiperco in forum Plumbing Forum Discussion & Blog
    Last Post: 02-25-2012, 02:16 PM
  2. Can I Use Any Thin Set With Kerdi? The ICC-ES Evaluation Report On Kerdi Says You Can
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 01-08-2012, 10:19 AM
  3. Use of 1/4 inch Hardie backer board on tub surround
    By nickhnw in forum Shower & bathtub Forum & Blog
    Last Post: 02-04-2011, 05:04 PM
  4. Kerdi Membrane
    By DanMcD in forum Shower & bathtub Forum & Blog
    Last Post: 11-21-2009, 05:21 PM
  5. Kerdi Showers
    By prashster in forum Plumbing Forum Discussion & Blog
    Last Post: 02-27-2006, 08:50 AM
