Results 1 to 5 of 5
Thread: Twist a joint after soldering?
    DIY Junior Member wheaty's Avatar
    May 2011
    Alaska
    Default Twist a joint after soldering?
    I'm a novice at this stuff. I soldered the male side of a 1/2 inch "street 90" connection into the 1/2 inch female opening of a washing machine valve. Just after I'd finished and it had just begun to cool I noticed its position wasn't quite what I'd had in mind. So I reheated it a little and twisted it (about 5 degrees) to the position I wanted. Is there a problem in doing that? Thanks for any advice.
    Probably okay...if you had run water through it, you would have had to remove, clean, then resolder. It can help to daub a little more flux on the joint when reheating one that's never had water go through it along with a touch of additional solder to help it reflow.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    No if you hold your tongue in the right place
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    May 2011
    Alaska
    Quote Originally Posted by MACPLUMB 777 View Post
    Thanks both. Tongue was held correctly. This saves me some worry.
    I usually apply a dab of solder to the connection after reheating it.
  1. Canadian dishwasher install...with a twist ;o)
    By bitsdoo in forum Canadian Plumbing Code Questions
    Last Post: 04-18-2013, 07:54 AM
  2. Has anyone used a LAKOS Twist II Clean Filter?
    By Joelk in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-25-2012, 05:11 PM
  3. Copper pipe ends oxidized inside near joint after soldering
    By k9mlxj in forum Plumbing Forum Discussion & Blog
    Last Post: 02-07-2011, 11:15 AM
  4. Common diverter problem with a twist
    By LJ in forum Shower & bathtub Forum & Blog
    Last Post: 06-06-2006, 05:03 PM
  5. Reheating Tee and twist
    By ToolsRMe in forum Plumbing Forum Discussion & Blog
    Last Post: 03-12-2006, 06:00 PM
