Page 4 of 4 FirstFirst 1234
Results 46 to 53 of 53
Thread: Well pump replacement - no water
  1. #46
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    There are a few different types of torque arrestor, one looks like a rubber disc, the other kinda looks like a football when it is opened up. If I were you, I would use the football type.
    LOL yeah get the damn thing fixed already!!!
    I hope you turned off your water heater when the pump quit, or you will be on another forum learning how to replace it.
  2. #47
    DIY Junior Member DYIWeller's Avatar
    Jan 2013
    Santa Fe, NM
    The arrestor type they carry here locally.
    "This Forum Rocks!"
  3. #48
    Jan 2013
    Santa Fe, NM
    The well pump and well pump motor, looked good.
    Do you know where I can find this electrical connector that plugs into the Gould Bruiser motor?
  4. #49
    Jan 2013
    Santa Fe, NM
    Is there anything else, I might Need?
  5. #50
    Moderator valveman's Avatar
    Mar 2006
    If that is a Franklin motor you will need a Franklin wire plug in. If it is a CentraPro, you will need to get one from Goulds. I am not sure they will interchange.
  6. #51
    Jan 2013
    Santa Fe, NM
    Thanks, found the lead plug-in, on their Manual, will call them tomorrow.
    Lead plug-in has three wires going in, and has two metal leads on the other end.
    All three wires were broken going in to the plug-in.
  7. #52
    Jan 2013
    Santa Fe, NM
    Update: Well is running, and water, and is crystal clear.
    Thank you all, for the tips and info.
  8. #53
    Apr 2012
    ct
    My bill is in the mail..............lol
  1. Recirculating pump not working after water heater replacement
    By Mmonagan in forum Water Heater Forum, Tanks
    Last Post: 01-13-2013, 11:54 AM
  2. water still dirty a week after new pump replacement
    By kmlowe in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-31-2012, 08:50 AM
  3. replacement pump not putting out water
    By ntrap50 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-29-2011, 09:06 AM
  4. dirty water after submersible pump replacement
    By jackofmosttrades in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2008, 05:42 AM
  5. Dirty water after well pump replacement...
    By mlblevins in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-20-2006, 11:04 AM
