Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 53
Thread: Well pump replacement - no water
  1. #31
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    I like a trench depth of 4-4 1/2' deep, but I have seen water lines at 2' that didn't freeze.
    You can certainly put more fill around the well, but I would rather see a new pitless installed and the line buried deeper.
  2. #32
    DIY Junior Member DYIWeller's Avatar
    Jan 2013
    Santa Fe, NM
    Quote Originally Posted by craigpump View Post
    Good advice. I will lower the pitless adapter.
    "This Forum Rocks!"
  3. #33
    Jan 2013
    Santa Fe, NM
    I'm not really understanding why the pump needs to be set so low with that much recovery but then I'm not a pumpman. Just seems like a lot of pump, a lot of wire, and a lot of pipe.
    What would be the recommended pump height for a 1 HP 10-15 GPM well pump?
    "This Forum Rocks!"
  4. #34
    Moderator valveman's Avatar
    Mar 2006
    Since the well recovers at 24 GPM, you only need to set the pump a few feet below the pumping level. But if you don’t know the exact pumping level, you need to set the pump back to 220’ like it was, because it is possible the water is coming in at 210’.
    If you had a water level gauge like the one in the picture, you could determine the exact pumping level. Without having an air line level gauge in this well previously, I would set it back as low as possible. Setting the pump as low as possible also keeps the bottom of the well from filling with sand.
  5. #35
    Jan 2013
    Santa Fe, NM
    Nice well water depth setup ... (looks like a new well), and clean job work to boot.
    Made some Jigs (fabricated tools), but lacking one more tool to get started.
    thanks all for your assistance and your patience.
    "This Forum Rocks!"
  6. #36
    Mar 2006
    Notice that my airline gauge reads 9 PSI, which means I have 20.7’ of water above my pump. But when I pump it hard the airline gauge drops to 1 PSI, which is only 2.31’ of water above my pump. This is how I know my pipe cannot be shortened as my pump cannot be raised higher in the well.
    Well is almost 20 years old. Removed fake rock for picture.
  7. #37
    Jan 2013
    Santa Fe, NM
    Default Pump Specs Decisions?
    I'm finding hard to decide on the configuration of pumps and and their specs.
    "This Forum Rocks!"
  8. #38
    Jan 2013
    Santa Fe, NM
    Default Well Casing Questions
    How do I go in lowering the pitiless?
    "This Forum Rocks!"
  9. #39
    Apr 2012
    ct
    Use the old one, you just have to cut the casing where the hole is and couple it together so you don't get surface water into the well.
  10. #40
    Jan 2013
    Santa Fe, NM
    Done with a couple of the fabricated tools made from scrap metal I found lying around.
  11. #41
    Jan 2013
    Santa Fe, NM
    As removed from well casing; photos showing exactly the well pump, and pump wires at pump, and the electrical splice connection for the well pump. no arrestor.
    The upper casing of well pump was loose and would slide up and down. Why would the pump shell separate and this caused the pump wires to short out?
    It was a Gould Bruiser Pump.
    "This Forum Rocks!"
  12. #42
    Apr 2012
    ct
    I like the drop of blood on the ground wire.
    Bruiser, what a piece of shit pump if there ever was one. I have pulled them when they were junk after less than 5 yrs.
    Notice how the plastic threads are destroyed? It looks as though the pump locked up and spun the jacket. Another good reason to use a pump with stainless ends.
    Tape splices are ok if done correctly, but that takes more time & costs more than using a heat shrink, so why do it?
    A lot of guys don't use a torque arrestor in pvc wells, but I think it is a good idea and good peace of mind for an extra few dollars.
    Your wife has the patience of a saint to go this long without water.
  13. #43
    Jan 2013
    Santa Fe, NM
    torque arrestors ? any differences?
    Today, the weather is beautiful, sun is shining and some fresh air.
    We can't wait to get this all fixed and back running again.
    "This Forum Rocks!"
  14. #44
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by DYIWeller View Post
    Nor can we. You should change your sig from "Just fix the thing now." to "Just fix the thing already!" Your wife must be very forgiving. Mine would be talking through a lawyer.
  15. #45
    Jan 2013
    Santa Fe, NM
    I'm trying my best, and with the help of you all in forum, this well will be up and running very soon.
    The bad weather the other factor, not a simple project,
    Thank you God!
    All is covered now.
    Just waiting on the new pump and other parts now.
    "This Forum Rocks!"
  1. Recirculating pump not working after water heater replacement
    By Mmonagan in forum Water Heater Forum, Tanks
    Last Post: 01-13-2013, 11:54 AM
  2. water still dirty a week after new pump replacement
    By kmlowe in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-31-2012, 08:50 AM
  3. replacement pump not putting out water
    By ntrap50 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-29-2011, 09:06 AM
  4. dirty water after submersible pump replacement
    By jackofmosttrades in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2008, 05:42 AM
  5. Dirty water after well pump replacement...
    By mlblevins in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-20-2006, 11:04 AM
