Results 1 to 7 of 7
Thread: noise in shower head
    DIY Junior Member blove1344's Avatar
    Sep 2012
    New Cumberland,PA
    Default noise in shower head
    My newely installed tub/shower has a squealling noise when the shower is turned on.
    It is a Moen valve and shower head and there is a loud squealling noise usually after
    the water has been on awhile. Then goes away and comes back later. It almost always
    makes this noise when you are shutting off the water. I changed shower heads but that
    did not solve the problem. I'm wondering if it is the valve itself of should I try another
    shower head? Has anyone else had this problem?
    Plumber jimbo's Avatar
    Squealing noise can propagate through the piping. One of the most common "squealers" is a main pressure regulating valve, located near the main house shut-off valve. You might look for that, and see if it is the source.
    Sep 2012
    New Cumberland,PA
    We are on a well system. I checked the tank pressure and it reads 50psi.
    Is there a tub/shower with a diverter in the tub spout? Those can be notorious for making some nasty noises. Most can't be repaired...replace it. Try playing with the knob on the diverter on the tub spout to see if you can change the sound if you have one.
    Sep 2012
    New Cumberland,PA
    Thanks Jim,
    It is the diverter! I'd never thought of that. I was ready to swap out the valve.
    Thanks again!
    One of the more reliable designs out there is made by Delta. The ones that have a ring around the spout that you pull DOWN to activate the diverter. They have them in many styles and finishes, but you may need to deal with the fitting to attach it. They do make a bunch of versions, though. You sometimes have to instruct guests on how to activate it, though.
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    "You sometimes have to instruct guests on how to activate it, though. "
    LOL I went to visit my buddy in Kentucky and that's what he had to do, lol. I never saw one like that, but I like it though.
  1. Adjusting the flow rate of a rain head (Shower Rain Head)
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 10-25-2012, 05:34 AM
  2. Neo Angle Shower advice needed... Where to put shower head or 2 maybe? MASTER
    By Jon Wawra in forum Shower & bathtub Forum & Blog
    Last Post: 06-22-2011, 12:33 PM
  3. To plumb a hand held shower or use diverter off of shower head
    By yakman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-02-2009, 09:56 PM
  4. Replace shower Plumbing Valve assembly shower head 2 knobs
    By scri8e in forum Shower & bathtub Forum & Blog
    Last Post: 12-30-2006, 10:24 AM
  5. Shower hot water issue - hot from tub faucet, lukewarm from shower head
    By mikea128 in forum Shower & bathtub Forum & Blog
    Last Post: 09-29-2006, 06:37 AM
