Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: question about amps
  1. #16
    Mar 2011
    Long Island, NY
    My Arris Cable modem takes 115vac right into it and has its own DC power supply built into it. My Netgear WNDR3400 Cablevision Router has an external 115 VAC Plug in unit which puts out 12VDC and plugs into the Netgear router.
    The important thing is to match the Power type (AC or DC) and the polarity of the plug matching the receptacle on the modem as to plus and minus pins. Of course this has been said several times here already, methinks
  2. #17
    Plumber jimbo's Avatar
    As an aside, one of the reasons for so many devices running on "wall wart" cubes..... anything running on 120 VAC has to be listed by UL or ETL or CSA. That listing process requires design considerations and many thousands of $$$$$$$$$$ for the application and cert. process. So you make 60 gazillion warts, which you get listed. The 12 volt device they feed does not require listing.
    Follow up: I noticed that my DSL modem, 12 volts, IS UL listed. That may be because it is also connected to the phone line. Or, I may not have the whole story straight! I am blaming the chemo~!
  1. What would cause a gas furnace to draw too many amps?
    By kailor in forum HVAC Heating & Cooling
    Last Post: 12-30-2011, 06:23 AM
  2. Amps/kilowatts follow GPM?
    By chas2010 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-25-2010, 10:09 AM
  3. Not enough amps for Toto Neorest/Now what?
    By Janjan in forum Electrical Forum discussion & Blog
    Last Post: 01-13-2010, 09:00 AM
  4. Not enough amps for Toto Neorest/Now what?
    By Janjan in forum Toilet Forum discussions
    Last Post: 01-04-2010, 11:01 AM
  5. 30 amps through #12 wire?
    By leejosepho in forum Electrical Forum discussion & Blog
    Last Post: 11-26-2008, 05:34 PM
