A regular constant speed, 15 GPM, ¾ HP submersible pump, can give you as much as 18 GPM at 50 PSI. A Cycle Stop Valve will turn that standard, single speed pump into a variable flow pump that will give you 18 GPM if you need it, and will deliver as little as 1 GPM when that is all you are using. The CSV can work with a very small tank as well. We recommend a 4.5 gallon size pressure tank like the one that comes with the Pside-Kick kit, as seen here.
