Results 1 to 15 of 22
Thread: no soft water
Threaded View
  1. #16
    DIY Member silversaver's Avatar
    Jan 2013
    Orange County, CA
    You need to make sure the valve is counting down the gallons of water you use. If not there probably will be no regeneration; unless you have calendar override on the valve.
    +1
    http://www.specsserver.com/CACHE/FILE2185.PDF
    WHES30 is very similar to my old GE Smartwater Profile. It will regenerate on demond or on calendar up to 15 day max.
    I thought my old GE water softener isn't working because it isn't generate any soft water... Check if the display will give you water usuage information. If not, that mean the valve isn't counting down the water. The valve could be bad or it needs to reset.
    What I did is shut off the main water valve to house and turn on fraucets to drain out the water within the pipes, then turn on the main water valve. Somehow my old GE softener start showing the water usuage and back to normal... too bad I have already order the new water softener...
    I'm not the expert but why not give it a try.
  1. Water inconsistently soft
    By wiz561 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-18-2011, 12:45 AM
  2. Water tests soft but doesn't feel soft.
    By ninefall in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-06-2010, 07:54 PM
  3. Need soft water
    By cvalko in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-23-2009, 11:29 PM
  4. No Soft Water
    By sbcoach in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-07-2007, 05:39 PM
  5. soft water to toilet
    By tjbaudio in forum Toilet Forum discussions
    Last Post: 12-18-2005, 05:18 AM
