Results 1 to 7 of 7
Thread: Opinions On Lightweight Drywall Panels ?
    DIY Member DavidSeon's Avatar
    Jul 2012
    MS Gulf Coast
    Default Opinions On Lightweight Drywall Panels ?
    The box stores around here are really pushing the newer lightweight drywall panels. I don't even see any of the traditional sag-resistant panels I had planned to use for textured ceilings; supposedly not necessary with the lightweight panels. I like the idea of lighter panels but I see a lot of complaints around the internet that they're more brittle, less flexible, dent and crack easily, don't block sound as much, don't snap as cleanly, etc. As a novice, I'd like whatever is the easiest to work with.
    Any opinions on these newer panels? Are the professionals using these now?
    Old Retired Computer Programmer
    Obsolete and loving it
    DIY Junior Member JackWills's Avatar
    Jan 2013
    Long Island, NY
    I prefer lafarage Gypsum, this is best according to me.. its fire resistant and meets with all your requirements.
    Jan 2008
    I have done 2 rooms inside and out with it. It feels a little different when cutting, snapping, and screwing, but I did not feel it was much different than working with the standard drywall. The reduced weight is nice if when hanging a ceiling by yourself.
    Jul 2012
    MS Gulf Coast
    Well, I guess it's a moot point; lightweight panels are the only "standard" gypsum panels available anywhere near here (other than greenboard and 5/8 fire rated). They can't even order the older, heavier panels now. So I guess I'll find out for myself what they're like.
    Thanks for the replies.
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    Quote Originally Posted by DavidSeon View Post
    I used some this weekend. No issues here. Is easier to work with.(Carry)
    DIY Senior Member diyfun's Avatar
    May 2011
    MA
    Can anybody put a link here? I am interested to look at it to see if I should use them as well.
    Licensed Building Contractor dtherrien's Avatar
    Jan 2010
    Massachusetts
    Most lumber yards and supply places are switching to the light weight sheetrock.
    I believe most of the problems are from big box supply places....I would recommend you buy from a lumber yard or a supply store that specializes in sheetrock.
    I know both lowes and home depot have had problems with there sheetrock in the past. Also it does have to be installed and finished correctly to insure you dont have problems.
  1. How to get even heat from h/w panels
    By aztom in forum Solar and Geothermal Water Heating Forum
    Last Post: 01-15-2012, 05:10 PM
  2. Access Panels
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-13-2010, 01:33 AM
  3. New Drywall Joined with Old Drywall
    By quinocampa in forum Remodel Forum & Blog
    Last Post: 03-14-2009, 04:23 PM
  4. Swanstone Wall Panels
    By BS in forum Shower & bathtub Forum & Blog
    Last Post: 02-26-2007, 06:06 PM
  5. carpet panels
    By ETHBilly in forum Remodel Forum & Blog
    Last Post: 10-20-2006, 06:11 PM
