Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Washing machine has no trap, what should i do to correct
  1. #16
    IF you want this to pass code, the WM pipe must be 2"...it cannot be 1.5". The WM outlet is pumped...it flows much faster than gravity would normally have water draining. With today's WM, you'll often have problems with an older (before they changed the code) 1.5" pipe - it will back up and overflow. Now, if the sink is lower than the top of the standpipe, it might just find that easier to drain into! If your existing WM doesn't have problems on a 1.5" pipe, when you do replace it, expect you probably will.
  2. #17
    Oct 2011
    doesnt the fitting in the bottom photo look like a vent T?? where in fact it should be a wye and an 1/8th like in the top diagram?
    Not saying your setup should be like this top diagram just pointing out the use of a wye and an 1/8th
  1. vertical distance to p-trap for washing machine
    By sam. in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-04-2011, 02:48 PM
  2. washing machine drain-p trap info
    By crazycraig68 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-02-2010, 12:32 PM
  3. Help with Washing Machine trap/drain/vent
    By schomeowner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-08-2008, 09:29 PM
  4. Washing machine trap
    By Giles in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-05-2008, 05:18 PM
  5. Trap on washing machine drain?
    By twojciac in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-17-2007, 01:48 PM
