Results 1 to 4 of 4
Thread: After Flapper Replaced....Multi-Flushes
    Plumber MichaelBukay's Avatar
    Jan 2013
    San Diego, California
    Default After Flapper Replaced....Multi-Flushes
    Been running into a problem and have already found an acceptable solution. I still question though; when I replace some standard-looking toilet flapper with universal fit flapper from the supply house, why do the toilets flush more than once per lever pull? The flapper will stay upright until the whole tank is evacuated. As if the water is preventing the flapper from falling back down. I was having this problem mostly on Kohler toilets that weren't too old. I was thinking maybe I should buy the OEM flapper for each brand of toilet I run in to. I found an adjustable flapper that has sufficed for now. Any thoughts?
    Few, if any, modern toilets since the mandated low-flow requirements, flush the entire tank during a normal cycle - they use the height of the water to provide more oomph for the flush. To accomplish this, they design their flapper to only stay up a certain amount of time. A universal replacement is unlikely to have that calibration, and will stay up longer, letting more water out. Enough water will cause it to do what you've seen. An adjustable flapper or an OEM, or one made specifically for your toilet as an aftermarket is the only way to drop the water use to the mandated amount. Using the wrong flapper, or incorrectly adjusting an adjustable one could use as much as twice the water mandated, and is a really bad thing in SoCal where water is especially dear.
    Jan 2013
    thank you Jim. Your information and input is helpful.
    Apr 2012
    New York, NY
    If you know the toilet brand and model number, and the flush valve hasn't been replaced, then call Korky customer service at
    262-763-2434 and ask them what's the best replacement flapper for your toilet. www.korky.com
  1. Mystery flushes
    By hollybegonia in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-06-2012, 12:41 PM
  2. Toto Drake red flapper vs blue flapper
    By DSWWPB in forum Toilet Forum discussions
    Last Post: 11-05-2011, 09:57 AM
  3. Flushes evry other time ??
    By nards01 in forum Toilet Forum discussions
    Last Post: 09-19-2010, 02:12 PM
  4. Flushes evry other time ??
    By nards01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-18-2010, 04:26 PM
  5. Toilet burps and then flushes ok
    By chuck652 in forum Toilet Forum discussions
    Last Post: 09-02-2008, 04:42 AM
