Results 1 to 2 of 2
Thread: How do I make the spout or spigot turn the right way?
    Questions from readers Guest's Avatar
    Nov 2005
    posts, emails and comments from readers reposted by Terry
    Default How do I make the spout or spigot turn the right way?
    My name is Nick, I'm an American living and running a small home school center in Malaysia and have some plumbing issues.
    My issue is that I would like to know the trick in making a spigot face the right direction when screwing it onto the pipe. Mine always tightens in the wrong direction. Should I use a lot of tape or pipe glue or washer?
    Nick
    If you are tightening a threaded connection, you have to decide when to stop. A tub spout or shower arm is similar. You can use thread sealant (dope) or Tape on the threads. I find that a few wraps of tape gives you more leeway in that situation.
    You don't have to bust a gut, just tight enough to prevent leaking.
  1. Hard to turn shower hot and cold Kolher 1/4 turn valve stems
    By magnumip in forum Shower & bathtub Forum & Blog
    Last Post: 11-11-2011, 06:31 AM
  2. no water, no sound when I turn spigot
    By Roberts in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-22-2011, 07:59 AM
  3. Crane tup spout won't turn
    By jimz in forum Shower & bathtub Forum & Blog
    Last Post: 07-31-2010, 08:39 AM
  4. Spigot Supply Valve - Pipe to outside spigot
    By drjimmy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2009, 05:03 PM
  5. Tub spout trouble, can I make this work?
    By ZappaFan in forum Shower & bathtub Forum & Blog
    Last Post: 05-13-2008, 04:00 AM
