Thread: Grundfos JQ1 Pump Question
    DIY Junior Member grassyhut's Avatar
    Jan 2013
    Australia
    Default Grundfos JQ1 Pump Question
    Hi, I have a Grundfos JQ1 pump that according to the suppliers needs a new pressure switch (Transducer).
    The pump won't start and gives 6 flashes on the red led on the control panel. I have also been told that the switch is no longer available.
    Does anyone know of any old stock. Alternatively, can this pump be modified to run continuously and use and external sensor.
    I have a reasonable knowledge of electronics so any info such as a circuit diagram or service manual would be much appreciated.
    Moderator valveman's Avatar
    Mar 2006
    Sorry but I cannot find any info on a JQ1. Apparently like all variable speed pumps it was designed to make the most money for the manufacturer, not to last.
    DIY Senior Member zl700's Avatar
    Aug 2009
    Texas
    I remember that pump has to be 15 years old. I used it on my cottage before I drilled a well. It was later replaced ** the JQ2&4 but those operated differently.
    12-16 years of service, time for a new one anyways.
    If Payback is so important to you, why are you not driving a Toyota Corolla?
  1. Grundfos Pump Protector
    By kminnich in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-30-2012, 11:26 AM
  2. Grundfos (or pump?) power usage
    By glchaparral in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-06-2011, 03:00 PM
  3. Grundfos CU-301 installation help with an unknown SQE pump
    By Brian.Hoard in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-23-2010, 09:04 AM
  4. Best GRUNDFOS recirculator pump?
    By Handiman in forum Plumbing Forum Discussion & Blog
    Last Post: 06-25-2009, 05:09 PM
  5. Replacement for Grundfos UP15-24F pump?
    By Ian MacMillan in forum HVAC Heating & Cooling
    Last Post: 11-20-2008, 09:46 PM
