Results 1 to 2 of 2
Thread: Need Advice for new shower Pan
    DIY Junior Member Dana D DeBoer's Avatar
    Jan 2013
    Colorado
    Default Need Advice for new shower Pan
    I have an 55yr old house built on a slab. I was getting water leakage out of the shower so i decided to tear out the old pan. I discovered after the demo that there was no slab under the pan, only dirt. This does not sound normal to me. What would be the proper steps to be taken to ensure a new solid shower pan?
    Thanks in advance for any help.
    dana
    Was there a liner somewhere in that mix, or just deck mud on the dirt? Some people consider the tile as a waterproof layer, but it is not. All current codes require a sloped, waterproof layer underneath the tile that is then tied into the drain. For stability, I think I'd want to pour a slab, tied into the existing slab with rebar drilled into the existing slab and epoxied in place. If you were considering a barrier free shower, this would be an ideal time to do it, since it would then be easier to recess the pan and get the slope you need for one.
  1. Neo Angle Shower advice needed... Where to put shower head or 2 maybe? MASTER
    By Jon Wawra in forum Shower & bathtub Forum & Blog
    Last Post: 06-22-2011, 12:33 PM
  2. Replies: 13
    Last Post: 07-28-2009, 05:43 PM
  3. Need Advice on Shower Faucet
    By mm530 in forum Shower & bathtub Forum & Blog
    Last Post: 11-12-2008, 10:32 AM
  4. Shower remodel advice please!
    By ecu pirate in forum Shower & bathtub Forum & Blog
    Last Post: 05-14-2007, 11:07 AM
  5. Advice on Shower Panel
    By moobiker in forum Shower & bathtub Forum & Blog
    Last Post: 08-18-2006, 03:26 PM
