Results 1 to 3 of 3
Thread: Recirculating pump not working after water heater replacement
Hybrid View
    DIY Junior Member Mmonagan's Avatar
    Jan 2013
    Culver City, CA
    Default Recirculating pump not working after water heater replacement
    I had my 40 gal hot water heater replaced and now the recirculating pump isn't working. The plumber feigns ignorance. My question(assuming its getting power): is there something that has to be done to the pump (priming?) to get it working again? The pump is a Grundfas.
    Feb 2011
    NW Ontario, Canada
    You may have to remove the heat trap on the hot outlet. It serves no purpose anyway if you use a recirc. My guess is the old tank didn't have heat traps.
    Feb 2011
    NW Ontario, Canada
    My other thought is perhaps some sediment got into the pump and it no longer turns.
  1. No recirculating hot water after water heater installation - photos
    By KarenS in forum Water Heater Forum, Tanks
    Last Post: 08-05-2012, 09:18 AM
  2. Shower stops working after water heater replacement
    By hiremichaelreid in forum Shower & bathtub Forum & Blog
    Last Post: 07-06-2009, 08:12 PM
  3. Dual water heaters with recirculating pump
    By LeonUGA in forum Water Heater Forum, Tanks
    Last Post: 05-28-2009, 06:51 PM
  4. Water heater recirculating question
    By Cass in forum Water Heater Forum, Tanks
    Last Post: 05-22-2009, 09:02 AM
  5. Recirculating loop stopped working
    By IowaSt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-22-2007, 07:11 AM
