Results 1 to 3 of 3
Thread: Calling Delta Experts: Do I have a 1500 or 1700 Series Shower Faucet/Trim Kit?
    DIY Junior Member BG in Detroit's Avatar
    Jan 2013
    Metro Detroit
    Question Calling Delta Experts: Do I have a 1500 or 1700 Series Shower Faucet/Trim Kit?
    Hello All, I'm a newbie to the forum. We built our house in 1997 and have a Delta Shower faucet that works fine but the polished brass has taken a beating and we need to replace the trim. We believe it's a Delta 1500 Series Monitor, but after surfing the web we might just have a 1700 Series. Escutcheon screw are at 2 o'clock and 8 o'clock. Here's a pic:
    Can somebody identify this, and also we would be interested if anybody had some of these trim kits hiding in the stockroom in polished brass.
    Thanks for the assist!
    DIY Junior Member Tee_14's Avatar
    Jan 2013
    Edmonton Alberta
    That is the 1700 series. You have both volume and temp control. Delta changed the valve so you might need to call them and see if they make a conversion kit so the new 1700 will fit it. According to the web site they have the Victorian in Polished Brass. Don't have my book in front of me to be sure.
    The 1990 Delta 1500 series did have the separate temperature knob. There is a conversion kit to make a modern 1700 series cartridge fit it. Your bolt hole seem to be located at the right locations for a modern trim kit. Call 1-800-345-DELT to see if your valve had the lifetime guarantee on the finish.
  1. Delta 1500 faucet - installing the RP28603 kit
    By chessie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-02-2012, 07:39 AM
  2. Shower trim kit for Delta 1500/1700
    By JohnBob in forum Shower & bathtub Forum & Blog
    Last Post: 10-20-2012, 08:56 AM
  3. Replacing a Delta 1300 series with a 1700 series
    By desvio in forum Shower & bathtub Forum & Blog
    Last Post: 12-30-2011, 06:42 AM
  4. help converting leaking delta 1500 to newer 1700
    By faroutofhere in forum Shower & bathtub Forum & Blog
    Last Post: 11-30-2008, 07:55 AM
  5. Delta 1400 Series shower faucet problem
    By bryanw21157 in forum Shower & bathtub Forum & Blog
    Last Post: 10-10-2006, 02:21 PM
