Installing Kerdi on a Neo Angle curb can be a little tricky. I've found when using Noble that if I place a relief cut in the top side of the curb I can not cut the sheet membrane at all and bend the fold that is generated by the neo angle curb into the top of the curb.
You can easily set a Kerdi Drain over that position.
If you try and keep your perimeter level you will have quite the creasing to deal with when the membrane goes down.
I would choose first what setting material company you plan to use for the job and then determine the thickness level of your mortar bed.
Are you building any shower niches? Sometimes working with a cementious membrane or liquid is easier here on the walls.
JW
