Results 1 to 2 of 2
Thread: Clattering pipes shower
    DIY Junior Member mrg65's Avatar
    Jan 2013
    Chapel Hill NC
    Default Clattering pipes shower
    Hi, my first post:
    I have a Danze shower fixture in an upstairs bathroom. When the shower is in the warm position the pipes can make a knocking sound. Turn it to all hot, no knock... all cold, no knock. When knocking i can open the cold water in the nearby sink and the knock temporarily stops.
    I don't have the experience to know if this is a sign of air in the pipes, a bad mixing valve, or something else. Hopefully you all can help.
    Thanks,
    Mike
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by mrg65 View Post
    When you do that, what is happening is the pressure balance spool valve is compensating for the drop in pressure on the cold side. That suggests that the spool valve is responsible. It is not necessarily defective, only that it has a particular point of resonance. You could try a different shower head with a different flow rate, or you could try replacing the valve.
  1. Pipes above my shower faucet
    By peet in forum Shower & bathtub Forum & Blog
    Last Post: 12-23-2012, 07:37 AM
  2. shower pipes
    By Nettlewarbler in forum Shower & bathtub Forum & Blog
    Last Post: 08-05-2009, 11:45 AM
  3. Shower pipes came unanchored
    By rpclmc in forum Shower & bathtub Forum & Blog
    Last Post: 03-18-2007, 07:27 PM
  4. leaks in shower and tub pvc pipes
    By caugie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-07-2006, 12:35 PM
  5. Vibrating shower pipes
    By cgrissom in forum Shower & bathtub Forum & Blog
    Last Post: 11-05-2006, 02:21 PM
