Results 1 to 6 of 6
Thread: Delay before water turns on in stall shower
Hybrid View
    DIY Junior Member Zagnut's Avatar
    Jan 2013
    Randolph, NJ
    Default Delay before water turns on in stall shower
    I have a problem with a two handle faucet on a stall shower. Recently neither the hot nor cold water turns on immediately when the handle is opened. There is about a 20 second delay. During that time some small amount of water trickles out and then the water flow suddenly becomes normal. This happens on both the hot and cold sides. The only change I have recently made was to install a washer on the hot side about 4 months ago to correct a drip from the shower head. I removed the valve stem and installed a new domed washer. That fixed the drip. Thereafter the shower worked fine. Now several months later I have this problem with the delay when the handles are turned on. At first the delay was not long, but it has gotten longer over the last month.
    It seems to me that after the shower is turned off the water must be leaking out of the line between the shower head and the valve. However, there is no evidence of leakage in the ceiling of the first floor below the shower. I am on a municipal water supply and have excellent pressure everywhere else in the house. I have stopped using the shower until I can figure out what is happening.
    The house was built in 1974 and has the original valve and stems.
    DIY Junior Member Tee_14's Avatar
    Jan 2013
    Edmonton Alberta
    Sounds like it is your shower head. Take your shower head off and see if there is any delay.
    Jan 2013
    Randolph, NJ
    I did take off the shower head and there is still a delay. There appears to be no mineral build up in the shower head. However, just to be sure I bought another one. Same problem occurs.
    Is it possible for the water to back out of the pipe to the shower head without there being a leak in the valve? It doesn't sound logical to me. However, There is no evidence of leakage below the shower.
    Depending on the valve design, an internal sticky part could do that.
    Jan 2013
    Randolph, NJ
    Thanks for your comments. I have come to the conclusion that I have to replace the valve. I have eliminated everything else as the cause. So even though I don't know why it is happening, I am convinced that the valve is the problem.
    Aug 2009
    South*East
    Check the faucet washers. It sounds like they may be loose or there is a piece of one floating around.
    John
  1. Delay in Toilet Water Refill, After Flush
    By sweetchic in forum Toilet Forum discussions
    Last Post: 10-19-2012, 07:20 PM
  2. Delay from when pressure switch clicks and pump turns on
    By Bobo in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-04-2012, 08:24 AM
  3. 1 minute + delay in getting water after pump kicks in
    By smokingtundra in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-10-2012, 12:57 PM
  4. shower the valve turns on by it's self
    By ghostvalve in forum Shower & bathtub Forum & Blog
    Last Post: 10-31-2006, 07:19 PM
  5. Very little hot water pressure in stall shower...
    By LNT619 in forum Shower & bathtub Forum & Blog
    Last Post: 06-01-2005, 07:53 PM
